VAG-hag
Experience dying leather
Nice one Bill, Cheers.
I seem to remember having a good chat with you at one point about colour changing but from memory you had your seats recovered? I have the same goal in mind as you :D
woudn't a grey to black swap be a lot easier chris? must be people out there wanting to go the other direction from you?
firstly hi chris,
and secondly i agree with dukest that the easiest way is to try and do a swap with someone as it will be the easiest way to do this, but if you wanna do it yourself then its an easy thing to do, but with doing the re-dying its like painting a car, the end job always depends on the prep work, if you rush getting the seats ready for dying it will look pants. So just take you time with the prepping and then the dying will be a very good job.
also get the dying equipment form the furniture clinic mate, they have been doing this for over 30 years so they are very good, put it this way Rolls Royce trust them enough to be there official repairer.
if you want any info when/if you start doing it just pm me mate.
karl
Thank you Gentlemen,
For now what i think ill do is put a wanted ad up..... ive always fancied some Recaros for mine 8)
Thanks again,
Chris.
im in the process of doing a full interior colour
change from grey to beige with a colour match to
storm interior trim,as said above prep is the key to
a good result and im using the furniture clinic
extra large kit which is very good,
spent a full day on prep so far and the results are amazing,
will throw up pics when im done if you want?
hello this is a piece of piss take a look at my build thread and see ok i havent changed the colour much but its exactly the same principle, however i have changed a few items from grey to beige with absolute ease....
i cannot reccommend this enough furniture clinic.com
like i say take a look and let me know what you think any questions feel free to ask
sorry about the delay on the pics
but was without my laptop for the past
fortnight :( ,anyway heres a few before and
after for you and also i cant recommend
the funitureclinic stuff enough,stick to
the instructions and you get serious results.
i completely stripped the interior for the colour change
these shots are after the leather prep,
you wont beleive the muck that comes off,
i went from a late interior to early so the doorcards were a
prob as i wanted to keep my late window switches
so back to furniture clinic for a repair kit and this was
the result
and the colour change
and fitted
red karmann badge :D
any questions id be happy help with.
I dyed my seats using the furniture clinic kit a couple of months ago and have used the car daily ( Take a look at my build thread: viewtopic.php?f=11&t=87868&p=1032257)
The only thing I've noticed so far is there's a bit of wear on the drivers upper bolster where the vinyl meets the leather. The wear is on the vinyl bit and because of the large bolsters of the colour concept Recaros it's very hard to get in without rubbing it a touch everytime. I've still got some left over so will sort it if it gets any worse.
Overall, Furniture clinic are really great to deal with, they'll even 'rent' you a compressor for free, which I would definitely recommend.
Andy
Love that colour change. I'm definately going to have a go at changing my grey leather to something else. Just got to decide what...
furnitureclinic are top class to deal with,
i bought the extra large kit with a colour match,
quick delivery and easy to follow instructions,
my rado is a daily so i gave the driver seat
2 coats of both laquers to be safe,
delighted with the finished result.
  bernie1033 said:
That looks fab in a red car! So much that you have inspired me to do mine from grey :D
the result
Do you have any more detail of filling the window switch hole please? What did you do about the texture of the leather vs the filler? Can you see there was ever a hole there now (doesn't look like it in the pics).
How did you pick the colour? Did you have something to match it to? I don't have any cream Corrado trim so I'm a bit stuck to get a factory colour....
Not that that necessarily matters, since its all changing from grey, but it would be nice to get it the right colour to match the parcel shelf :cat:
when i filled the holes in the doorcards
i just peeled the leather from where its
attached to the hole on the back of the
doorcard you then end up with the hole
closed,then with the leather repair kit you
have a piece of webbing which you cut to
size and glue behind withe the leather glue
after that has set its filler time and that is
a case of repeating until perfect,the instructions
you get with the kit are very good but i found
when filling the doorcards that patience will leave
it perfect,on the colour match i got my colour
matched to a piece of trim and now they have my
colour on file,the code i have is corrado yu 20g,
im very happy with the match so use that code if you
want that colour,any more questions feel free to ask,
regards,,bernie.
