be here now
g60 running probs
Hi hope someone can help iv got a g60 engine in my golf the engine is out of a 92 corrado its got a sns chip 68 mm pully
an g60 golf intercool the problem is the boost gauge nedle on it bounce,s up an down tht fast it,s a blur then some times mybe once out ten times it will
be ok but sits at 800ish on the dial can any one help thanks ric
How is the car behaving?
Sounds more like an electrical issue either with the guage wiring or the guage itself?
Is it driving/idling/pulling ok?
Gauge issue, double check the boost pressure at the ECU MAP sensor by using the MFA dignostic mode.
Have a read of this thread to see how to do it.
