leeeeshad 0 Posted February 4, 2010 Hi, i was checking the mirror switch hoping to find out why they dont work (the adjustment that is, they reflect fine :lol: ) and i found this The back of the mirror switch with plug and bit of loom and the loom in the door, with a connector that dosent fit the switch what the hells going on? Quote Share this post Link to post Share on other sites
dgtvr6 0 Posted February 4, 2010 Not a case of a late interior in an early car (or opposite way round) is it where whoever did it just butchered the loom and left it? Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted February 4, 2010 Im not sure, its grey leather in a J reg G60, is that standard? and can the 2 be connected? cheers Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 4, 2010 Not a case of a late interior in an early car (or opposite way round) is it where whoever did it just butchered the loom and left it? Im going to guess, that from the pictures its a late car, with an early fitted interior (the design of the switches) and the guy who fitted it cut it as you said but couldnt work out the wiring loom as they look to be different colours, i can source you a wiring diagram if you want ive got them all from when i re did all of mine. That is if you dont mind doing a bit of soldering, or i think ive got the original loom for the mirrors as i changed from early to late... Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted February 4, 2010 the window switch is wrong aswell, its upside down, as if its from the left door on a left hand drive, the hole its in looks bodged to, maby it has had a swap a diagram would be great thanks, i was looking for a haynes manual but there isnt one Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 4, 2010 Im not sure, its grey leather in a J reg G60, is that standard? and can the 2 be connected? cheers AFAIK its not standard but J reg (or 92) was the crossover year like mine although i did think that all G60's were early spec...might be wrong, if the connectors are different then no, you cant just connect them lol but as i said above you can splice it easily enough Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 4, 2010 the window switch is wrong aswell, its upside down, as if its from the left door on a left hand drive, the hole its in looks bodged to, maby it has had a swap a diagram would be great thanks, i was looking for a haynes manual but there isnt one Infact looking at the picture again its kinda REALLY messed up. The position of the switch is that of a late interior, the earlys had the switchs higher up on the door card whereas the lates have them in the storage/speaker plastic. It appears to be that they have replaced some of the parts but mixed the late and early together...odd [strike:3re1odyt]Out of curiosity have you got a picture of the mirror switch i think ive got an idea....[/strike:3re1odyt] Ok i've figured out what has happened here, i was correct about your car being early spec, what the previous owner has done is buy a late leather interior but hasnt managed to get all the switches. Your mirror switch is late as it is in the grab handle of the door, the earlys were much higher up. He hasnt managed to replace any of the looms which is why the switch isnt connected. the looms are still that of the early hence why he has used an early window switch and butchered the socket to make it fit. You've got 3 choices: -Splice new loom for window switch and mirror switch, however you'd need to get the connectors for the loom and a late spec window switch (or you could just do the mirror) -Replace the doorcards for early leather door cards, that way the connectors and switches are the same, however you'd need to get an early spec mirror switch -buy new looms and fit them, Ok i have found the wiring diagrams for both early and late however for some reason there appears to be WAY to many cables coming from the socket in the switch...can you confirm to me the colours coming from the switch, thanks. Jay Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted February 6, 2010 The wires on the switch are no1 brown/black 2 white/green 3 yellow/brown 4 blue/black 5 black/yellow 6 black/grey 7 black/red 8 brown door loom 1 brown 2 black 3 blue 4 red/blue 5 black/yellow 6 White those numbers are molded into the connectors, the mirror switch looks like it's been butchered into the handle so it may not even be from a corrado :s Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 6, 2010 ok well according to my wiring diagram (for both early and late) there should only be 6 cables going into the mirror switch and they are the same for both early and late: 1 Brown 2 Black 3 Blue/Red 4 Blue 5 Black/Yellow 6 White The thing is that the cable already in the switch isn't supposed to be there AT ALL lol the previous owner clearly just found one that he thought 'fitted' Here is the wiring diagram for the late spec but its the same for early just so you can look yourself: corrado94 p33.jpg[/attachment:emq0d16a] So in your case (if his socket fits ok and the terminals connect properly) i would assume you could splice it like this: SWITCH------------------------>DOOR LOOM Brown/Black----------------->Brown White/Green---------------->Black Yellow/Brown--------------->Blue Blue/Black-------------------->Red/Blue Black/Yellow----------------->Black/Yellow Black/Grey-------------------->White And don't worry about the extra colours (sockets 7 + 8 Hope that helps :) Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted February 6, 2010 Thanks, where did you get the info? Iv been looking for a haynes manual but can't find one Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 6, 2010 haynes manuals dont exist for the corrados unfortunately....you have to either buy a bentley manual (expensive!) or just look on here for info :) Quote Share this post Link to post Share on other sites
