Wild-Animal 2 Posted March 14, 2010 Hey i have had a corrado for just shy of a year as I bought it on my birthday, for my VAG history well I had a polo if I showed picture of that I would be thrown of the forum. You could go round any corner at 5 mph and the rear FREE tyres would be screaming at you :lol: was to be a feild car until someone tried to hot wire it for some reason, o well lucky the battery was dead. Since I have had it, not alot has been done until recently oh yeah it a g plate 1.8 119000, couldnt resist having one after spotting a couple of them they look so good. Immobiliser fitted profeesionally, then he wondered why the fuse box was looking a bit funny, as it was upside down. So the Electrician sorted that all out. Timing belt change Water pump replaced. Central locking pump replaced Bump strips taken off Uprated headlight loom ETKA Corrado.pdfC Front end no plate.jpg[/attachment:233n58sb] Corrado94.pdfC Front end no plate.jpg[/attachment:233n58sb] Corrado conversion V2 (3).pdfPICT1389.JPG[/attachment:233n58sb] Book1.pdfPICT1386.JPG[/attachment:233n58sb] stromlaufplan_gamma4.pdfPICT1317.JPG[/attachment:233n58sb] Recently the engine has been removed hopefully get some pictures of the removal, just planning on cleaning the bay up Re tapped all of the wiring loom with some proper tape New power Steering pipes Changed the power steering rack, got one of the forumn as VW wanted £950 for the rack on its ownits and they could not even guarantee it was the correct rack. For some reason? stromlaufplan_gamma4.pdfrear end no plate new2.jpg[/attachment:233n58sb] Okay, i started to take things apart decided take the engine out to clean things up and change a couple of things eham sort of engine crane Corrado92.pdfPhoto0033.jpg[/attachment:233n58sb] passat climatronic wiring diags.pdfPhoto0035.jpg[/attachment:233n58sb] Okay so i got the subframe off I work as a Blacksmith so i blasted everything at work, we have a heavy grit not sand blaster so I took my time and made sure there was no rust left on the pieces glad I blasted it myself as it took a while even with the heavy grit. climatronic wiring-Golf from May 01.pdfPICT1429.JPG[/attachment:233n58sb] Then proceeded to Zinga the heck out of everything and then primer then under seal thew coats of each... PICT1459.JPG[/attachment:233n58sb] Re tapped the wiring loom and have some rusty bits to sort out started on the battery tray just made a plate up at work, work in progress and the lucky sill someone could not operate a jack properly! Quote Share this post Link to post Share on other sites
streetpreache47 0 Posted March 14, 2010 nice clean rado that pal, I have never really looked back from getting mine! Love it, I like how standard your car looks, especially the cool steels! Quote Share this post Link to post Share on other sites
streetpreache47 0 Posted March 14, 2010 PS what do you use to clean your engine>? Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted March 15, 2010 haha safe to say the engine came like that!I am cleaning the engine while it is out with Jizer, you could try that. Thanks for the kind words! Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted April 14, 2010 Corrado92.pdfPICT1460.JPG[/attachment:b0b58rso]Corrado92.pdfPICT1460.JPG[/attachment:b0b58rso] passat climatronic wiring diags.pdfPICT1461.JPG[/attachment:b0b58rso] could you guess my age ? :lol: climatronic wiring-Golf from May 01.pdfPICT1442.JPG[/attachment:b0b58rso] 2.8l 24v Climatronic system.pdfPICT1452.JPG[/attachment:b0b58rso] PICT1453.JPG[/attachment:b0b58rso] Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted April 14, 2010 :lol: good effort mate. I like the front view. But the wheels make me laugh :lol: Could you send me a slice? :norty: Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted April 27, 2010 A slice, I need the cake to put the car together! :D Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted August 3, 2010 Hey needing a little help, the existing steering rack seals were shot as fluid was leaking so in the rebuild I sourced a second hand rack, was told the rack would fit the car as it does ,once I had changed the splines form the inside the rack that connect onto the steering coloumn as they were differently splined. The prob was when I built the car up the wheels, they would no where near track up straight. Checked the lengths of the track rods and they were different, the second hand rack arms were longer by say 50mm. So i ordered not through VW (cost a bomb) but at Dingbro new track arms and they arrived and yet still longer than what originally came off? But the track arms were the same length as the track arms off the second hand rack? Any info would be so much help! Thanks Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted September 20, 2010 I got the steering rack rods sorted out just need to get it a MOT a couple of things it failed on headlight pattern and handbrake not working enough, the amount of time the dude had a look at the car and the time he took i am glad that was all ! I have been getting distracted as well! :D PICT1657.JPG[/attachment:374nv73q] Quote Share this post Link to post Share on other sites
big ben 10 Posted September 20, 2010 what, riding a girls bike :lol: only joking, looks nice Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted November 1, 2010 Haha girls bike pfff nothing girly about the price of that bike :eek: Oh yeah my car has passed its M.O.T also solved the problem of starting the car when its warm by changing all of the injectors to new ones ! I have a new accumulator to put on it once i can get a bit of pipe from the fuel filter to the accumulator sourced found something cool on piston heads http://www.pistonheads.com/sales/2206063.htm Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted November 21, 2010 So i got the accumulator changed to a new one, i have noticed the difference well other than one looked like a bag of rust climatronic wiring-Golf from May 01.pdfPICT2207.JPG[/attachment:1ssb6bu0] then in with the new one also replaced the pipe from the accumulator to the fuel filter 2.8l 24v Climatronic system.pdfPICT2206.JPG[/attachment:1ssb6bu0] The brackets got the rust buffed off then zinga'd and anti stone chipped put back on with new washers and spring washers as i did not want to over tighten them due to the rubber bushings they sit on. PICT2208.JPG[/attachment:1ssb6bu0] Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted November 22, 2010 With it all back in situe, one of the studs did snap on me so i had to drill out the stud and replace with a shiny bolt, passat climatronic wiring diags.pdfPICT2213.JPG[/attachment:t3ov36km] My trusty jack :norty: climatronic wiring-Golf from May 01.pdfPICT2205.JPG[/attachment:t3ov36km] The accumulator got a good thew coats of anti stone chip, keep it in tip top condition! Also some rust got attacked at the rear end 2.8l 24v Climatronic system.pdfPICT2212.JPG[/attachment:t3ov36km] So next plans are to get the tank straps off blast them at work along with the rear bumper bar, its a heavy grit blaster works alot better on removing rust than a sand blaster, only thing is i am thinking every single one of those bolts are going to shear! :shock: during the build PICT2074.JPG[/attachment:t3ov36km] Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 22, 2010 nice work butty Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted December 19, 2010 Our new lot of snow there is gonnna a be a whole lot more ! 2.8l 24v Climatronic system.pdfPICT2317.JPG[/attachment:3qz6g08f] passat climatronic wiring diags.pdfPICT2315.JPG[/attachment:3qz6g08f] The throttle was sticking so badly i wasnt sure what it was so i done some investigating. The cable started to fray a bit and it was ctaching on the casing of the cable. climatronic wiring-Golf from May 01.pdfPICT2319.JPG[/attachment:3qz6g08f] So i trimmed the sharp pieces of and greased it up as a temporary measure .What a difference ! its so much more responsive :clap: I cant wait to get a new one on . The prob was mainly when changing gear the car would rev up between gear changes as the throttle was not backing off quickly enough a bit annoying when you are trying to keep a Type R from overtaking :norty: PICT2305.JPG[/attachment:3qz6g08f] I also made a panel to stop the water sitting ontop of the battery Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted December 20, 2010 good stuff mate 8) Quote Share this post Link to post Share on other sites
Rinse 0 Posted December 21, 2010 Nice work! Looks pretty clean, hopefully see if kicking about Edinburgh! Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted June 28, 2011 So keeping myself busy with firends cars and my own, my friends Capri needed some welding done especally on the headlight holder, the A pillar, front vallace and also the floor. Well basically its ford .... So got that all sorted. He recently got the car resprayed in Matt black so its looking smoothe Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted June 28, 2011 So I have fitted a new fan to the radiator this is a pic of the old one, the whole fan assembly was moving backwards and forth so at some pint it would have self distruct, so I changed it before that happened. Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted June 28, 2011 I removed the fuel tank and the rear bumper. Then blasted the tanks straps and rear bumper bar, treated them to some Zinga and under sealed twice. Replaced the bolts also. Since the tank was off I gave a good clean outside and inside removing any bit s rubbish in it. The car was never the best to start when it was warm so a while back I changed the injectors so it starts fine now when its warm. You can see a picture of an old injector it looks pretty past it. The injectors must have been leaking. Still the car was not the best for starting when it was cold, so I have replaced the in line fuel pump, the lift pump, fuel filter and I had changed the accumulator a while back. Now it starts a lot easier from cold yeppee Since I am heading up uni at sunny Aberdeen I changed the rear brakes from the Mk2 rears to the Mk3 rears, safe to say the difference is huge on my last M.O.T I had big problems with the handbrake efficiency. So I changed the discs as well and fitted a new heat shield. So there is a picture of the old calliper which I will be glad never to see again ! Also I fitted the in line fuse for the headlight switch it only took a couple of mins to do. Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted June 28, 2011 So the fuel pump and the lift pump. The lift pump was tricky to change there is a metal coupling that holds onto the lift pump connection so make sure your not in to big a rush in changing it as I had to take my time to removing the old one carefully. The in line pump was okay to change, I made sure I got a Bosch one as I wanted to make sure it would give me the correct pressure. Quote Share this post Link to post Share on other sites
