John-M 0 Posted March 17, 2010 I have the door card off - to repair the door handle - and the door membrane is well past its use-by date. I have got some replacement polythene, but what to fix it to the door metalwork with ?? One of the doors had what looked like double-sided tape - which was a nightmare to clean up, so I'm reluctant to use that again. The other door looks like it has the original VW stuff - black rubbery mastic which is still, after all these years, soft to the touch and allows the membrane to be removed easily. But I'm having difficulty finding where to get any more of that 'mastic'. So, what has anyone else used to attach the membrane to the door when getting in there to repair door handles, fix leaks, install soundproofing, etc etc ?? Thanks in advance ... ... Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 17, 2010 i've used some double sided foam type tape, is about 3mm thick, 10mm wide. Quote Share this post Link to post Share on other sites
fla 9 Posted March 17, 2010 i got some roof sealant on a reel - it looks like grey blue tac which can be unrolled and stuck on. However, the black stuff already there will also be fine, justb remove the membrane and clean it up with white spirit, that'll make it tack again. Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 17, 2010 I know the problem, stil lhaven't found the right stuff myself. Whatever you do though make sure the small drain holes pressed into the bottom edge of the inner door skin opening are just above the sealant line when you affix the membrane, otherwise water will get trapped in the bottom of the membrane. Quote Share this post Link to post Share on other sites
John-M 0 Posted March 21, 2010 Thanks for the above - I'm on the track of something that sounds like it will do the trick. Will report back :) Quote Share this post Link to post Share on other sites
volksworld13 0 Posted March 21, 2010 i think i may have the equivalant vw stuff at work, its very very sticky, and looks exactly like the stuff used from factory, will get part number and pic. Quote Share this post Link to post Share on other sites
John-M 0 Posted March 21, 2010 That would be very useful, thanks :) Quote Share this post Link to post Share on other sites
8vMatt 1 Posted March 21, 2010 Is there any reason why silicon can't be used? Quote Share this post Link to post Share on other sites
RaddoMan 0 Posted March 21, 2010 hot gule gun works wonders :D Quote Share this post Link to post Share on other sites
dragon green 4 Posted March 21, 2010 Ive just this minute re-sealed mine with silicone mastic, if i had seen the above post,i would have dug my glue gun out ! Quote Share this post Link to post Share on other sites
RaddoMan 0 Posted March 21, 2010 yeah rememer to put gloves on , as the gule will be hot 8) Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted March 21, 2010 I was unsucessful with silicone as it did not want to dry. The stuff below worked well for me http://www.screwfix.com/prods/54342/Sealants-Adhesives/Adhesives/Grab-Adhesives/High-Performance/Evo-Stik-Wet-Grip-Adhesive-290ml;jsessionid=2DL1ZHNG34JIQCSTHZOSFFI#reviews Quote Share this post Link to post Share on other sites
Toad 0 Posted March 21, 2010 I used pink duct tape. Works well. Quote Share this post Link to post Share on other sites
Wullie 1 Posted March 21, 2010 Pink sounds lovely :camp: Quote Share this post Link to post Share on other sites
Toad 0 Posted March 21, 2010 Pink sounds lovely :camp: Was a present from Dinkus. :luvlove: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 21, 2010 Guys, just use the VW stuff - it's fantastic! Duck tape will dry out in a couple of years, I used elephant tape 5 years ago and it's only just started to fall off, silicon stinks and you can't re-use where the VW stuff sticks but you can peel back the membrane and re-fit several times if needed. Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 22, 2010 so what exactly do you ask the dealer for then? bearing in mind most parts depts struggle to cope with the simplest of requests :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 22, 2010 Door embrane sealant I guess - TPS had it in stock when I asked for it, was about £8 I think Quote Share this post Link to post Share on other sites
John-M 0 Posted March 22, 2010 I was in my local dealer's last week asking about this - membrane no longer available, replacement no longer available, sealant no longer available ... ... Anyone got any part numbers for 'the VW stuff' ( the sealant ) ?? Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 22, 2010 I was in my local dealer's last week asking about this - membrane no longer available, replacement no longer available, sealant no longer available ... ... Anyone got any part numbers for 'the VW stuff' ?? Service no longer available :lol: I just bought 100m[sup:10m2sycj]2[/sup:10m2sycj] of polythene sheet from Screwfix to line my garage for spray painting stuff, might knock up a few door membrane 'replacements' and put them on e-bay :lol: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 22, 2010 I was in my local dealer's last week asking about this - membrane no longer available, replacement no longer available, sealant no longer available ... ... Anyone got any part numbers for 'the VW stuff' ( the sealant ) ?? John, go and see Neil at Ips Audi - 3A0867201H - FOAM MEMBRANE AKL43401925 - DOUBLE SIDED TAPE They appear to have replaced the sealant with tape - I will see if the part number off the stuff I have still exists.... Quote Share this post Link to post Share on other sites
Toad 0 Posted March 22, 2010 I just bought 100m[sup:2vdn7s5x]2[/sup:2vdn7s5x] of polythene sheet from Screwfix to line my garage for spray painting stuff, might knock up a few door membrane 'replacements' and put them on e-bay :lol: I used silage clamp sheet, probably the same thing. Was going to make up some sets of membranes and flog them, but I'm way too lazy. Quote Share this post Link to post Share on other sites
volksworld13 0 Posted March 22, 2010 so when you ask for a membrane, they are no longer available, im sure i remember seeing a roll of plastic sheeting listing instead of the ready made membranes, which you have to make your self.? Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted March 22, 2010 I was in my local dealer's last week asking about this - membrane no longer available, replacement no longer available, sealant no longer available ... ... Anyone got any part numbers for 'the VW stuff' ?? Service no longer available :lol: I just bought 100m[sup:1b3yx8ps]2[/sup:1b3yx8ps] of polythene sheet from Screwfix to line my garage for spray painting stuff, might knock up a few door membrane 'replacements' and put them on e-bay :lol: you wouldn't be the first :lol: Quote Share this post Link to post Share on other sites
John-M 0 Posted March 23, 2010 3A0867201H - FOAM MEMBRANE AKL43401925 - DOUBLE SIDED TAPE They appear to have replaced the sealant with tape - I will see if the part number off the stuff I have still exists.... FOAM membrane ?? Surely foam isn't resistant to water getting through ?? I have acquired some polythene to make replacement membranes with, now just after the mastic stuff to stick it on with, One of my doors had had double-sided tape on from a previous body-repairshop - and it was a nightmare to clean off to get a good surface to start again with. Quote Share this post Link to post Share on other sites
