lion 0 Posted April 18, 2010 heey guys, i've had a small leak in my boot for a long time, finally found where problem is, but all my carpet has mould on under the spare wheel, i've washed it all out but it still stinks. my mate told me that the mould can come back, whats the best way to get rid of it for good? Quote Share this post Link to post Share on other sites
lion 0 Posted April 18, 2010 anyone? would like to tackle problem today Quote Share this post Link to post Share on other sites
g60jaime 10 Posted April 18, 2010 I would start by cleaning the carpet you would with any other interior upholstery and take it from there. If you have eliminated the conditions in which the mould grew, then I wouldn't have thought it would come back. If it does come back you might have to tackle in an anti-bacterial method. I'm sure there are some car specific anti-bacterial cleaners out there for the job. When interior house decorating to tackle persistant mould and mildew, Polycell do an antibacterial treatment for this purpose. I don't know what it is like for soft furnishings as it is not intended for it, (you aren't supposed to paint those bits), so read the label and test an area first. You don't want to find it has bleach or corrosive properties. Hope this helps a little... Quote Share this post Link to post Share on other sites
Skyway 0 Posted April 18, 2010 Always thought sugar soap tackled mould without bleaching and prevents it from returning as long as the conditions prevail. Quote Share this post Link to post Share on other sites
Veearrhsix 0 Posted April 18, 2010 Just woken up, so prob would've given you this post earlier if it wasn't for my job... (vents spleen for irrelevant avail) Heard a dash of white vinegar here and there will do the trick to get rid of the mustiness, as well as clean the mold. But add other softer agents like fairy liquid too I reckon. White vinegar's on the right track anyways - but don't go overboard. Afterwards - stick a dry bar of soap (of your choice) in an open-top container and leave in there for a month or two... Great alternative to the endless short-life scents/fragrances out there on the market that will do feck all to your motor. Also - generally, as damp will build in your car anyhow, buy some of those dishwasher salt crystal stuff (Tesco do a 3kg bag I think). Dart a few containers (of matching design to your coloured trim) of the stuff around the interior - out of view and bingo... no more damp. On a side note my car stinks of the scent sticks I burn on my dash when driving - although I like the smell and smoke - :nono: Probs not wise while driving though, but reminds me of meditation classes from way back - so it chills me out when driving. Anyway - not food (a banquet) for thought but definitely something to mull about. Quote Share this post Link to post Share on other sites
lion 0 Posted April 18, 2010 thanks for all the replies, i washed out the boot carpet and spare wheel well today, cleened the jack and wheelbrace too it was that bad. just used some fairy for now, still smells bad so i will use some of ur ideas tomorrow, ill let u know how i get on :salute: Quote Share this post Link to post Share on other sites
Erny 0 Posted April 20, 2010 Vinegar kim n aggy style, I use it on the window n sunroof seals Quote Share this post Link to post Share on other sites
fla 9 Posted April 21, 2010 as its sunny atm, put the carpets out to dry and turn them every so often to make sure mould spores are dried up and killed off. If you can, then leave the boot and doors open, drop the rear seats and let the wind blow through the car for several hours. You may also want to use some stick on insulation in the boot, even something like Damplifier used to reduce panel vibration. This will mean that there is notsuch a cold surface for condensation to take place. Most importnatly, chck you dont have water ingress into the boot from eg the tailgate or from the spare wheel well bolt hole, or maybe even the rear quarter windows, otherwise you'll be constantly playing catch up with the mould. Quote Share this post Link to post Share on other sites
GOGG60 0 Posted May 29, 2010 Hi I've come late to this but also have leaking boot problems. Nothing obviuos when sprayed with hose. Grateful for any tips. Quote Share this post Link to post Share on other sites
lion 0 Posted May 29, 2010 Hi I've come late to this but also have leaking boot problems. Nothing obviuos when sprayed with hose. Grateful for any tips. my leak was coming from behind the bumper, just at the top where it meets the body.. thrown the carpet away but just making do until i can afford the spray job Quote Share this post Link to post Share on other sites
GOGG60 0 Posted July 12, 2010 Hi I've come late to this but also have leaking boot problems. Nothing obviuos when sprayed with hose. Grateful for any tips. my leak was coming from behind the bumber, just at the top where it meets the body.. thrown the carpet away but just making do until i can afford the spray job Thanks for that, but what's a 'bumber'? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted July 12, 2010 for eliminating mould and doing a good job at getting rid of smells i've used this in the past.. http://www.petsathome.com/shop/cat-urine-stain-and-odour-remover-trigger-spray-945ml-by-simple-solution-15204 looked for a while at cleaning solutions and it came up as a recommendation.. had no probs since.. Quote Share this post Link to post Share on other sites
lion 0 Posted July 12, 2010 Hi I've come late to this but also have leaking boot problems. Nothing obviuos when sprayed with hose. Grateful for any tips. my leak was coming from behind the bumber, just at the top where it meets the body.. thrown the carpet away but just making do until i can afford the spray job Thanks for that, but what's a 'bumber'? ment bumper lol. Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted July 12, 2010 There's a connection in the rear washer hose on the left about level with the rear shelf supports but behind the C-pillar (both need to be removed) mine was leaking there. Reconnected it properly and then wirelocked it on, never leaked from there since. 8) All this chat about anti-bacterials? Mould is a fungus, use some fungicide!!! Quote Share this post Link to post Share on other sites
