jma 0 Posted May 2, 2010 Hi I am trying to fit the window scrappers that fit along the outside of the door (I did not have any fitted I bought the car). I have removed the door cards and the inner window scrapper. I have fitted the drivers side but it does not fit tightly against the window (when glass is down its perfect tight against the glass but when the window up there is a gap its getting on my nerves!. I am trying to remove these and the problem is I cant take them off :mad2: :mad2: :mad2: . Please could anyone advice me on how can I remove these!!!! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 2, 2010 they are a fit once item, they are scrap if removed but if not 100% fitted tightly, you might be lucky if you ease it out gently to do it properly, unbolt the glass and drop it into the door out of the way. Lube the window strip with fairy liquid and push it on from the top of the door, making sure the bottom edge feels like it slots home inside the door, that's the critical part. Quote Share this post Link to post Share on other sites
jma 0 Posted May 3, 2010 they are a fit once item, they are scrap if removed but if not 100% fitted tightly, you might be lucky if you ease it out gently to do it properly, unbolt the glass and drop it into the door out of the way. Lube the window strip with fairy liquid and push it on from the top of the door, making sure the bottom edge feels like it slots home inside the door, that's the critical part. How do I unbolt the glass? sorry for being silly there always a first time for everything! :brickwall: Quote Share this post Link to post Share on other sites
