Supercharged 2 Posted May 13, 2010 Sticky? Get ur finger out! Should have been done in 2005 Hi Chris - well that 2005 thread was actually stickied and I will leave it for now like that. Quote Share this post Link to post Share on other sites
RW1 0 Posted May 13, 2010 Hi Steve, This one would be better now to sticky as it pulls in all the info and the other is referenced by Dave's first posting. Just add this one, don't I think there's anything else lying around??? viewtopic.php?f=19&t=19701 . Quote Share this post Link to post Share on other sites
big ben 10 Posted May 13, 2010 what a thread, will be doing this very soon on the VRT Quote Share this post Link to post Share on other sites
Philmo 0 Posted May 13, 2010 This sounds a little like the old Ford V6 in Scimitar self combusting scenario caused by interference fit petrol feed pipe in carb casting working loose, filling the Vee with fuel and woosh! Standard solution - refit using Araldite. Say Dave - does this apply to the later switches also? Quote Share this post Link to post Share on other sites
JMC 0 Posted May 13, 2010 Just get the standard 3mm 12V led's from Maplins mate. Most of the switches are 12v (apart from the window switches) and the headlight one definately is. Too dim, tried that type first, miles dimmer than the standard little green bulbs. Tried Maplin's 3 volt ones, again at the time not bright enough. Needs a pair of bright LEDS. LEDs were green from maplin, part number N30BY http://www.maplin.co.uk/module.aspx?moduleno=45930 End up with a metal film resistors from RS Spares part number 144-295, 2.7K ohm, Metal Film 0.125w. Now superceded http://uk.rs-online.com/web/search/sear ... &x=29&y=15 (You need this physical size to get the resistors in without fouling the mechanics.) Maplin at the time didn't offer 0.125w resistors. And note the two small insulating sleeves in the photo on page 1 of my postings. The LED lens for the ring illumination need "damping" or it looks unbalanced so I painted a black blob of touch-up paint on the crown of the lens. This is the LED furthest from the dimmer control. Don't bother with paint on the other as it not as transparent and it needs the direct beam of the LED onto it. The fuse I used was a 1 amp standard blade fuse like the Corrado's type. Dave's 200 mA fuse will work just as well. I tested the 1 amp fuse on a length of same wire across a battery's terminals direct. Fuse blew, wire - no damaged found, it was instant. My switch operates a BRMotorsport headlight loom. It is always stone cold. Sticky? Get ur finger out! Should have been done in 2005 :lol: This topic has it all in one spot now for the headlight switch problems. No excuses now!!! . Strange, never had a problem with them for the early headlight switches (and I've done loads of them). Had to take the existing green filter in the switch out though, and with the late headlight ones it pays to dremel down the opaque plastic below the icon as that could be causing it to look dim. Also the led's are very critical on alignment - a few degrees off and they look dim. If you can be bothered to you can get 120 degree dispersed ones, but they are normall low voltage and need resistors. Quote Share this post Link to post Share on other sites
CrazyDave 0 Posted May 13, 2010 This sounds a little like the old Ford V6 in Scimitar self combusting scenario caused by interference fit petrol feed pipe in carb casting working loose, filling the Vee with fuel and woosh! Standard solution - refit using Araldite. Say Dave - does this apply to the later switches also? Seem to be a problem on all the switches, even brand new dealer ones sometimes :shock: . So best to test them out as per RW1's guide before fitting :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 13, 2010 Yeah, I think the issues with LEDs is the light is very directional with most having a 15 degree viewing angle... JMC - any chance you have a list of part numbers used for the switch LEDs??? Did you also say the late windows switches were not 12V? Quote Share this post Link to post Share on other sites
JMC 0 Posted May 13, 2010 Yeah, I think the issues with LEDs is the light is very directional with most having a 15 degree viewing angle... JMC - any chance you have a list of part numbers used for the switch LEDs??? Did you also say the late windows switches were not 12V? Green leds in Maplin are WL33L. However you might be better looking for ultrabright low voltage ones on ebay. They are much brighter but will need to be fitted with a resistor. Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 13, 2010 factory fit window switches run to the window control unit so don't need to be 12v as don't feed the motors directly, I assume the updated roof electrics are similar, whereas the early roofs are a direct power switch to the motor with no auto features. Quote Share this post Link to post Share on other sites
RW1 0 Posted May 13, 2010 Yeah, I think the issues with LEDs is the light is very directional with most having a 15 degree viewing angle... Yup, was part of the problem in the late version switches I have. Hence the route with the Maplin one I posted earlier. The more directional, the more problematical the illumination as the switch cover symbol and "ring" move relatively to the LED beam. Right for one switch position, go to the other end of the switch rocking, the illumination has disappeared. . Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 13, 2010 Previous owner of my car installed a MK2 golf headlight switch after the original one broke fingers crossed havnt had a problem with it yet and doesnt look too out of place :D Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 13, 2010 Previous owner of my car installed a MK2 golf headlight switch after the original one broke fingers crossed havnt had a problem with it yet and doesnt look too out of place Is the mk2 golf headlight switch a straight swap with the corrado. Does any one know if it needs to be modified ? cheers Quote Share this post Link to post Share on other sites
dragon green 6 Posted May 13, 2010 Previous owner of my car installed a MK2 golf headlight switch after the original one broke fingers crossed havnt had a problem with it yet and doesnt look too out of place Is the mk2 golf headlight switch a straight swap with the corrado. Does any one know if it needs to be modified ? cheers Sraight swap :D Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 13, 2010 whether the mk2 headlight switch will stop the loom fire is another problem :shrug: Quote Share this post Link to post Share on other sites
RW1 0 Posted May 13, 2010 Not really. Its VW's way of fusing circuits that leads to the problem. The 12 volts to the switch no matter which wire input are not fused. This earth wire if made to contact inside a switch....... Mk2 switch may be more robust but if it does fail, effect will be the same. For a few bob, it's peace of mind. . Quote Share this post Link to post Share on other sites
Philmo 0 Posted May 13, 2010 This sounds a little like the old Ford V6 in Scimitar self combusting scenario caused by interference fit petrol feed pipe in carb casting working loose, filling the Vee with fuel and woosh! Standard solution - refit using Araldite. Say Dave - does this apply to the later switches also? Seem to be a problem on all the switches, even brand new dealer ones sometimes :shock: . So best to test them out as per RW1's guide before fitting :) Don't want to push it - but are you set up for testing on sat? :ignore: Quote Share this post Link to post Share on other sites
dragon green 6 Posted May 15, 2010 Took some pics of the headlight switches,sorry about the quality,not the easiest of subject matter ! bottom is Mk2 golf middle early Corrado top late Corrado All fit the Corrado Took pics of the rear of the switches,the top 2 (Corrado) are exactly the same ! the bottom one (Golf) has 2 pins missing, but still works on the Corrado. Iam sure someone will be along to tell us if its a good or bad thing Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 15, 2010 I darent look at the back of mine incase its been bodged :confused4: Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 15, 2010 Going off the pic on page 1 looks like on a mk2 golf switch that the wire that Dave is cutting wont connect to a pin because there isnt one Quote Share this post Link to post Share on other sites
dragon green 6 Posted May 15, 2010 Going off the pic on page 1 looks like on a mk2 golf switch that the wire that Dave is cutting wont connect to a pin because there isnt one Yep thats the earth wire ! Perhaps thats why the Mk2 doesnt suffer the same problems as the C . Cant remember if the Golf one illuminated or not,cant try it g/f has borrowed the car :( Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 15, 2010 my used to illuminate now it doesnt think its the bulb Quote Share this post Link to post Share on other sites
krnau 0 Posted May 18, 2010 shouldn't fuse be placed on the positive-side wires instead of the negative one? Just to ask! Quote Share this post Link to post Share on other sites
RW1 0 Posted May 18, 2010 The point of the fuse in the earth wire is to protect due to an "unusual" failure in the switch. ie. the switch goes mechanically u/s and leads to a short or as stated can be supplied new with a soldering fault internally (numerous have occurred that I know of since the first I came across in 1997). The headlight fuses are after the headlight switch in the circuit. VW assume loom wiring will be generally safe once installed. By splitting the circuits after the switch, more of the circuits continue to work if one unit in the circuits fails resulting in a short circuit. ie. if a headlight bulb shorts on failure, then the other headlight bulb continues to operate. To put a fuse ahead of the switch means a large fuse rating ~40 - 50 amps. With a fuse that size, the earth wire would be toast before the fuse blew or would probably delay the circuit protection and some damage would result to the loom between the headlight switch and the fuse relay panel. . Quote Share this post Link to post Share on other sites
krnau 0 Posted May 18, 2010 perfect, just what I needed to know :) thanks! I'll be doing it shortly :) Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 22, 2010 I have just done this mod today…and got one of my index finger burnt in the process :( So be careful with this !!! Never done soldering in my life :) Glad I got it done. Guess I wont be attempting the LED mod version of this as I dont think I can afford to get any other fingers burnt in the process :) On the VR6 there wasn’t much “extension” for me to work on once I've disconnected the headlight switch. So had to take all the lower trims out to get to it from the bottom up The finish article. Have to say thanks to Crazy Dave for this mod. Otherwise would have never known about this issue :D Quote Share this post Link to post Share on other sites
