A5 VRX
Key locks
Sorry if this is in the wrong area Mods so please move if needs be,
Does anyone know if the lock barrels (both doors and ignition) from my 1990 mk2 Golf would fit onto/into my Corrado VR6?
Thanks
Adam
Why do you want to change the barrels? If its the same type of key (AH) then you can change the bits in the barrels to fit that key..
Ignition barrel is knackered after some idiot tried to pinch it from the previous owner, still usable but really needs replacing. Got a mk2 that i'm breaking with all the locks left inc ignition,
Adam
Yep I've a got a spare, only thing is when you retumble you will probaly need a different configuration of tumblers so you could do with some spares. I've got some but didn't want to give them all away as I'd like to keep some as spares. I'm sure we can work something out.
Do you want to collect or should I post?
Dave
