CazzaVR 0 Posted August 11, 2010 Glad it's all OK Dave 8) Fancy doing mine? :lol: Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 11, 2010 just bought this for doing mine: beam.jpg[/attachment:2hbt4204] e-bay ad Quote Share this post Link to post Share on other sites
dannyboy 0 Posted August 11, 2010 is that the proper lifting frame? looks like it! how much did that cost? Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 11, 2010 it's just an engine and transmission support beam, sits on inner wing tops and has two separate hooks one to support engine and the other to lower the g-box, (some beams only have one hook/lifter) the e-bay ad has the price :) £50 + £9 delivery Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 11, 2010 Well done. Quote Share this post Link to post Share on other sites
Jim 2 Posted August 11, 2010 Brilliant result - glad it's all back together again :) Quote Share this post Link to post Share on other sites
pete_griff 0 Posted August 12, 2010 glad to hear it's all sorted for you - you must be well chuffed :) @ David Wort - those engine supports are invaluable when doing this sort of job on a rado - saves much f'ing about! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 12, 2010 pete_griff said: @ David Wort - those engine supports are invaluable when doing this sort of job on a rado - saves much f'ing about! Not so much invaluable - VW say you have to use them with the front bumper off for anything engine / clutch / mount related. Quote Share this post Link to post Share on other sites
pete_griff 0 Posted August 12, 2010 that's interesting! i guess that's a health and safety thing... when i did my subframe i just supported the back of the engine on massive blocks of wood via the sump and was v careful when lowering/raising it. they make things so much easier though and still leave you room to work around things without gearbox jacks etc getting in the way underneath Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 12, 2010 The good old release fork strikes again :roll: :D Quite a common issue really. Especially on uprated clutches with double stiffness tangential springs, or original clutches past half worn and have become heavy. The fork can't handle the increased load and bends. It's a bit of a naff design and is why VW upgraded to concentric release bearings on the 02M and newer boxes. When people take their boxes off, I seriously recommend an uprated fork, such as this one - http://www.flipsidecustoms.com/OnlineStore.php I had a new fork modified by Stealth's fabricator, but it's easily something you could make Dave :norty: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 12, 2010 kevhaywire said: It's a bit of a naff design and is why VW upgraded to concentric release bearings on the 02M and newer boxes. : Because they are so much more reliable! :lol: The original fork is a fairly serious piece of metal - obviously I can see why and how they can get bent etc with hydraulics being involved but it's normally a cylinder failure that leads to this from what I understand. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 12, 2010 Well yeah, they fixed one problem and created another! The fork bending is common enough for some companies to make an uprated one. In fact I wouldn't run an uprated clutch without one tbh. Quote Share this post Link to post Share on other sites
daves16v 1 Posted August 12, 2010 kevhaywire said: The good old release fork strikes again :roll: :D Quite a common issue really. Especially on uprated clutches with double stiffness tangential springs, or original clutches past half worn and have become heavy. The fork can't handle the increased load and bends. It's a bit of a naff design and is why VW upgraded to concentric release bearings on the 02M and newer boxes. When people take their boxes off, I seriously recommend an uprated fork, such as this one - http://www.flipsidecustoms.com/OnlineStore.php I had a new fork modified by Stealth's fabricator, but it's easily something you could make Dave :norty: Yeah I could have re-inforced it no problem but I didn't know it was such a big weakness, I doubt I'll have the car when it decides to let go again, anyway that box is staying put, not going through that again. I've still got my old one so I might see what I can come up with. Quote Share this post Link to post Share on other sites
