luke w
Will a late grill fit an early Corrado?
As the title says, will I be able to fit the later grill to my early (1990) Corrado?
I've seen people mention whether or not the front panel and slam panel are early or late which has got me wondering whether that would mean the grills may not be able to be swapped over?
can be done ,but yea the panel has the slots in different place .ive got the early 16v grill on mine ,one of the tabs should be in the right place the others need to be carefully cut off, then plastic weld or something simular the others in the right place .
Think it's only the bottom middle tab that needs to be cut off- at least, that's all I had to do to get my FK debadged grille to fit my early valver.
There are a couple of tabs to be decapitated. Then use zip ties, they were designed for corrado repairing :lol:
