VWVW 1 Posted September 20, 2010 I am looking to buy a caliper rewind tool. There are so many out there...which one would you recommend ? cheers Quote Share this post Link to post Share on other sites
dukest 0 Posted September 20, 2010 I bought this as it seemed the best priced. I've bent the t-bar at the top a bit by forcing it with an extension but you can also put a socket on the end which means its not a big deal. For the number of times you'll use it I cant see its worth spending more than you have to. Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 20, 2010 I've got the same one, ideal for VW rear brakes, around £20 from halfords. Quote Share this post Link to post Share on other sites
bbewekim 0 Posted September 22, 2010 I'm just confirming the above. I bought this the other week, good enough build quality for the job. Should be suitable for my 312 front calipers with a bit of patience :D. Quote Share this post Link to post Share on other sites
TimDoc 0 Posted September 22, 2010 if you dont want to buy one, a large G-Clamp and a pipe pair of pipe gripping pliers with some rubber to line them. Tighten the G clamp and twist the caliper back in! - worked a treat on my mates s4 brakes! T Quote Share this post Link to post Share on other sites
carrots 1 Posted September 22, 2010 i would borrow 1 for the amount of times you change your rear pads Quote Share this post Link to post Share on other sites
