VWVW
Which caliper rewind tool do you recommend ?
I am looking to buy a caliper rewind tool. There are so many out there...which one would you recommend ?
cheers
I bought this as it seemed the best priced. I've bent the t-bar at the top a bit by forcing it with an extension but you can also put a socket on the end which means its not a big deal. For the number of times you'll use it I cant see its worth spending more than you have to.
I'm just confirming the above. I bought this the other week, good enough build quality for the job. Should be suitable for my 312 front calipers with a bit of patience :D.
if you dont want to buy one, a large G-Clamp and a pipe pair of pipe gripping pliers with some rubber to line them.
Tighten the G clamp and twist the caliper back in! - worked a treat on my mates s4 brakes!
T
