vw rule 19 Posted October 4, 2018 Ahh got you. I was like, how does he know that lol I will update on here when we get news. We will probably be looking for someone to test fit the sample once it arrives. Its the same manufacturer that did the VR6 backing plates we did Hi Anna I've started a new thread regarding the above item, when you guys at Heritage have any update, please post up in the attached thread, or if I hear anything I'll post up. http://the-corrado.net/showthread.php?108692-Part-number-191-803-483-(fuel-filler-neck-repair-panel)&p=1213925#post1213925 Many thanks Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted November 16, 2018 Part number 535 129 627A Plastic air intake pipe Corrado 2.0 8v (eng 2E) 1993 - 1994 £179 euros in stock Part number 535 129 627D Plastic air intake pipe Corrado 2.0 8v (eng ADY) 1994 - 1995 £43.95 euros in stock Part number 3A0 129 627E Plastic air intake pipe Passat / MK3 Golf 2.0 16v (eng ABF) 1992 - 1996 £139 euros in stock Part number 035 133 847 Plastic / rubber bung for item above. Length 34mm Diameter 18mm Passat / MK3 Golf £1.39 euros in stock Part number 021 133 374E Rubber breather hose from Idle control valve to silencer chamber Corrado 2.9 VR6 (eng ABV) £12.95 euros in stock Part number 021 133 374D Rubber breather hose from silencer chamber to throttle body Corrado 2.9 VR6 (eng ABV) £11.95 euros in stock Part number 034 133 517 Recirculate solenoid valve (Possibly redirects fuel vapor fumes from vapor canister to throttle body) Corrado 2.9 VR6 (eng ABV) £169 euros in stock Part number 021 133 518H Vacuum hose from recirculate solenoid valve to throttle body Corrado 2.9 VR6 (eng ABV) £80.96 euros in stock Part number 021 133 518G Vacuum hose from recirculate solenoid valve to throttle body MK3 Golf 2.8 VR6 (eng AAA) £54.95 in stock Part number 021 131 503A EGR valve Corrado 1992 - 1994 (Possibly for USA spec Corrado) £519.01 in stock All the above is in stock at VW Classic Parts in Germany, speak to VW Heritage first. Si Quote Share this post Link to post Share on other sites
_Matt_ 33 Posted March 18, 2019 Hi Anna, Is there any chance the vdo centre console gauges could be re-produced for RHD cars? I'd love a set and I've seen quite a few others are hunting them down too. How many people would have to be interested to get it done? Since 2nd hand sets are going for between ~£300 each I'd be happy to pay that sort of money for a re-pro. Quote Share this post Link to post Share on other sites
annavr6 10 Posted March 18, 2019 Hi Anna, Is there any chance the vdo centre console gauges could be re-produced for RHD cars? I'd love a set and I've seen quite a few others are hunting them down too. How many people would have to be interested to get it done? Since 2nd hand sets are going for between ~£300 each I'd be happy to pay that sort of money for a re-pro. Probably not to be honest. Its quite a complicated part and obviously there is a limited amount of cars that have it. The hard part is trying to convince the boss to do anything for Corrado as obviously there are less of them than Golfs. We do however have some reproduction Corrado sills coming in which i hope will be of an OK quality Quote Share this post Link to post Share on other sites
Keyo 49 Posted March 18, 2019 Probably not to be honest. Its quite a complicated part and obviously there is a limited amount of cars that have it. The hard part is trying to convince the boss to do anything for Corrado as obviously there are less of them than Golfs. We do however have some reproduction Corrado sills coming in which i hope will be of an OK quality Hi Anna , Are these the sill trims that have the Corrado lettering or the late plane trims. Cheers Quote Share this post Link to post Share on other sites
annavr6 10 Posted March 18, 2019 Hi Anna , Are these the sill trims that have the Corrado lettering or the late plane trims. Cheers No, these are the outer metal sill repair panel Quote Share this post Link to post Share on other sites
_Matt_ 33 Posted March 18, 2019 Probably not to be honest. Its quite a complicated part and obviously there is a limited amount of cars that have it. The hard part is trying to convince the boss to do anything for Corrado as obviously there are less of them than Golfs. We do however have some reproduction Corrado sills coming in which i hope will be of an OK quality Thanks for coming back to us, that's a shame but I get it from a business point of view. Sometimes wish I bought a mk2 Golf instead - waaay easier to spend money on.... Quote Share this post Link to post Share on other sites
vw rule 19 Posted June 9, 2019 (edited) This item 1H0 201 449 is still available at VW main dealers and is used on Audi's, VWs and Skoda 1988 to present. This clip is a one piece clip that can hold four 8mm (1/4") fuel pipes. Cost per each is £3.42 For more details on this item please see link below: Hope this helps Si Edited November 11, 2020 by vw rule Attached link wasn't working so has been changed/updated. Quote Share this post Link to post Share on other sites
Bush 10 Posted July 23, 2019 Probably not to be honest. Its quite a complicated part and obviously there is a limited amount of cars that have it. The hard part is trying to convince the boss to do anything for Corrado as obviously there are less of them than Golfs. We do however have some reproduction Corrado sills coming in which i hope will be of an OK quality Hi Anna. Are the sills available yet? Do they go all the way back to the rear wheel arch? How much are they? Quote Share this post Link to post Share on other sites
annavr6 10 Posted July 24, 2019 Hi Anna. Are the sills available yet? Do they go all the way back to the rear wheel arch? How much are they? Hi We have done nothing with sills. My colleague Neil did find a repro sill available so we got one i9n, which is here somewhere. When we compared it to the original genuine one we had, the profile is close, but not quite right so we decided not to stock it. We have been pushing the people higher up to do more Corrado but they just think there are hardly any corrados left. I think there are more Corrados then they think with USA and Europe too. Anyway my proof of this to them is that the Corrado headlight protectors we made have out sold the mk2 Golf and Mk3 Golf versions! So we will keep pushing them to do more Corrado Quote Share this post Link to post Share on other sites
_Matt_ 33 Posted July 24, 2019 That is great news Anna and thank you for pushing the Corrado. We will be at risk of these cars dying out completely if parts can't be sourced and for many we are rely on your company!! Quote Share this post Link to post Share on other sites
annavr6 10 Posted July 24, 2019 The good thing was that my colleague Neil bought a Corrado which was scrap as it happens. Anyway when he first got it he needed bits to repair it and we didnt have them. So this has helped as now he is also on the case of pushing the appropriate people. Quote Share this post Link to post Share on other sites
Keyo 49 Posted July 24, 2019 The good thing was that my colleague Neil bought a Corrado which was scrap as it happens. Anyway when he first got it he needed bits to repair it and we didnt have them. So this has helped as now he is also on the case of pushing the appropriate people. Hi Anna, Can you ask Vintage rubber in the States to send you some samples over of their various trims and see if you can strike up a partnership, also try and lower their prices with bulk. Many obsolete trims available including window scarpers. http://vintagerubber.com/volkswagen/corrado/ Cheers. Quote Share this post Link to post Share on other sites
annavr6 10 Posted July 25, 2019 Morning, I did speak with Vintage rubber before as they do the roof rubber part on a Mk2, well part of it, but they were very expensive with no discount if i remember correctly meaning we would have to sell their parts for alot more than they do. This was a while ago though so might be worth another ask. We do get an air order every month from the USA and a sea order also once per month. Quote Share this post Link to post Share on other sites
Keyo 49 Posted July 25, 2019 Morning, I did speak with Vintage rubber before as they do the roof rubber part on a Mk2, well part of it, but they were very expensive with no discount if i remember correctly meaning we would have to sell their parts for alot more than they do. This was a while ago though so might be worth another ask. We do get an air order every month from the USA and a sea order also once per month. Thanks Anna, think VR are missing A TRICK by not finding a partner in Europe could certainly increase their sales considerably. Have samco got the machining to make these seals , might be worth SHOUT. Quote Share this post Link to post Share on other sites
annavr6 10 Posted July 25, 2019 Thanks Anna, think VR are missing A TRICK by not finding a partner in Europe could certainly increase their sales considerably. Have samco got the machining to make these seals , might be worth SHOUT. Samco dont have alot of machines, most the samco hoses are made by hand which is why their lead time is so rubbish. Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 17, 2019 (edited) Tried my local VW Dealer but was told the part in question is possibly obsolete, as the parts guy couldn't see it available on his screen. Anyway found the item in question on the VW Classic Parts site: Part number 051 133 556 Retaining clamp for fuel injectors for Corrado 1.8 16v (KR) and 2.0 16v (9A) x4 are fitted. Cost per each €1.80 = in stock. Si Edited August 17, 2019 by vw rule Quote Share this post Link to post Share on other sites
annavr6 10 Posted August 19, 2019 Tried my local VW Dealer but was told the part in question is possibly obsolete, as the parts guy couldn't see it available on his screen. Anyway found the item in question on the VW Classic Parts site: Part number 051 133 556 Retaining clamp for fuel injectors for Corrado 1.8 16v (KR) and 2.0 16v (9A) x4 are fitted. Cost per each €1.80 = in stock. Si £1.29 plus VAT each from Heritage, free delivery over £50 Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 19, 2019 £1.29 plus VAT each from Heritage, free delivery over £50 Thanks Anna :thumbleft: Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 27, 2019 Just got off the phone with my local VW Main Dealer,these two items are no longer available through them, been obsolete now since July 2018 Power Steering retaining bolt x4 fitted Part number N901 845 02 Nuts for the above bolts x4 fitted Part number N902 264 04 So I'll probably look on Fleebay, and find / use some Flange hexagon bolts that are zinc plated and high tensile grade 8.8 Because the original bolts have those annoying splines on the head stem, that can make them a real pain to remove / fit. Hope this helps Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 28, 2019 (edited) Just got off the phone with my local VW Main Dealer,these two items are no longer available through them, been obsolete now since July 2018 Power Steering retaining bolt x4 fitted Part number N901 845 02 Nuts for the above bolts x4 fitted Part number N902 264 04 So I'll probably look on Fleebay, and find / use some Flange hexagon bolts that are zinc plated and high tensile grade 8.8 Because the original bolts have those annoying splines on the head stem, that can make them a real pain to remove / fit. Hope this helps Si Right think I've found some on eBay. Ebay seller Kayfast Ebay item number 362293650219 These are M8 X 80mm long with thread pitch 1.25mm, thread is 24mm long and these are shouldered flanged bolts = flange is 18mm plus are high tensile 8.8 zink plated. Hex head of bolt is 13mm spanner size. Original bolts are M8 X 75mm long high tensile 8.8 EBay item number 161819587642 Nuts I've gone for flanged nylon lock M8 zink plated with 1.25mm thread pitch to match new bolts. Hex nuts are 13mm spanner size. EBay item number 181048351786 Washers gone for stainless M8 lock serrated, these will help keep the bolts tight to subframe and lock nuts tight. Si Edited August 28, 2019 by vw rule Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 28, 2019 I've used a local fasteners for bolts, and they are a _lot_ cheaper than eBay This is who I use locally, there will be surely one local to you too https://www.selkentfastenings.com/ (M8 X 10 HEXAGON SETSCREW HT 8.8 BZP (DIN 933)) x 10 for £0.35 inc VAT Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 28, 2019 Oh fair play, yeah I've tried some of my local places near me but weren't much cop, including Screwfix. Hence getting them from EBay. Those original retaining bolts for the power steering rack are a nightmare to get out sometimes, probably not a bad thing they are obsolete now. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 15, 2020 Looks like VW Classic Parts have stock now of the front hub assembly for both sides for the 4 cylinder Corrado's, just been having a look on their website and came across them, for ages they only stocked / listed the VR6 front hub assembly's. Corrado (8v 2E / ADY) (16v KR / 9A) (G60 PG) 4 cylinder front hubs: Right side (O/S/F) Part number 357 407 255C Left side (N/S/F) Part number 357 407 256C Cost £116.00 euros = £105.12 per each. Si Quote Share this post Link to post Share on other sites
Keyo 49 Posted July 15, 2020 (edited) 18 minutes ago, vw rule said: Looks like VW Classic Parts have stock now of the front hub assembly for both sides for the 4 cylinder Corrado's, just been having a look on their website and came across them, for ages they only stocked / listed the VR6 front hub assembly's. Corrado (8v 2E / ADY) (16v KR / 9A) (G60 PG) 4 cylinder front hubs: Right side (O/S/F) Part number 357 407 255C Left side (N/S/F) Part number 357 407 256C Cost £116.00 euros = £105.12 per each. Si Does it say genuine or reproduction - they have a lot of parts in that warehouse that they have not yet recorded for sale trust me there will be some right gems in there sitting in boxes - lucky they don't do open days or easypos would be in there with a fork lift heading right for the VSR dusty box section and recaro trims 😉 Edited July 15, 2020 by Keyo Quote Share this post Link to post Share on other sites
