CazzaVR
OEM VW Parts Price Enquiries
I take it you mean front grille? I don't believe they are though unfortunately for you I had a mint one which has been sold. I do know spoonfed tuning do an early style reproduction which is really good.
yes meant front grill
thats a shame about the dead production
spoonfed tuning one is nice but i think i prefere it with the badge. ...its all about the rear extended spoiler with spoonfed though ;)
any clues as to what these early grills go for second hand then as you recently sold one? ...can pm if thats a better idea
been down to the dealers this week so have a few prices:
Oil Pressure Switch High and Low (VO28 919 081 H/V068 919 081 D) £12.62 Each
Thermostat (V075 121 113 D) £24.91
Thermostat O-ring (VN 901 368 02) £3.84
Oil Cooler Gaskets
(V038 117 070) £3.25
(V038 117 070 A) £4.24
Oil Filter (V021 115 562) £14.60
Prices are all without VAT.
Additional Parts that I didn't buy so only got rough prices:
Thermostat Housing (all 3 parts inc. gaskets) approx. £75.00
Crack pipe inc. O-rings approx. £30.00
Impulse Sender (Camshaft sensor as far as I am aware) approx. £52.00
In addition the dealer said they were unable to get the Engine Speed Sensor (Crankshaft position sensor I think this is) any longer, so it might be worth stocking up on this as I understand it's a showstopper if it goes wrong!
  lapisb said:
Are the white plastic sill trim retaining clips still available?
Part no? Cheers
Got them today from dealers
Phoned my local VW Dealer ealier today for a few bits,
and got some prices.
Throttle cable for 2.0 16v Corrado is £30.59 + VAT
Part number is V536-721-555
Gearbox speedo sensor (VSS) is £25.46 + VAT
Part number I think is V191-919-149D
Clutch hydraulic metal pipe complete with flexi hose,
VW only list the early one from 1989 to 1992 which is about £68.00
told me they no longer list the pipe for the later Corrado's from 1992 to 1996
So I'll probably make my own pipe up and use a brake flexi hose with female ends,
so I'll be able to screw the pipe in at each end,
this way only the flexi hose has to be replaced if it bursts and not the whole pipe,
like on the original set up.
Si
Edited by vw rule
  annavr6 said:
front early grilles are available from the VW Heritage website, from classic parts
Anna - could you please confirm if the 'late' grille is the summer type with open slats?
rather than the so called 'winter' type which has the closed slots in the grille
thanks
It may be worth checking on the Classic Parts website directly as they do often photograph the actual stock they have in their warehouse (rather than use a 'library picture') - you may be able to ascertain whether it's the closed or open slat variant of the grille.
Actually I've just taken a look (see attached picture) and it does seem to be the open slat variant :)
superb! thanks jim & joe i had seen the image was open slat but thought id ask anna to confirm just in case it was a stock image as you say
anna - quick response as ever & thank you for confirmation :)
A few more part numbers and prices here that I've got from my local VW main dealer,
items below are for the 4 cyl 16V, g60 and 6 cyl VR6 Corrado's.
The front inner anti roll bar bush clamp bolts,
part number is N019-538-9 cost is £0.48 + VAT per each.
2 of these are fitted.
Front subframe rear retaining bolts,
part number is N102-575-01 cost is £1.48 + VAT per each.
Just be aware that the last time I bought these the thread pitch was slightly different,
so had to drill out the old thread and fit a stainless helicoil.
Ignition switch part number is V6N0-905-865
cost is £27.50 + VAT
Rear axle beam rear bush bolts, part number is N903-544-01
cost is £2.17 + VAT per each.
Nuts to fit the above axle bush bolts, part number is N903-237-06
cost is £2.58 + VAT per each.
Rear axle retaining bracket bolts, part number is N101-417-01
cost is £1.81 + VAT per each.
6 of these are fitted = 3 to each side.
Front wish bone arm front bush bolt (shoulder bolt)
part number is N904-840-04
cost is £1.95 + VAT per each
2 of these are fitted = 1 to each side.
Front wish bone arm rear bush bolt (shoulder bolt)
part number is N102-078-04
cost is £2.64 + VAT per each
Front cross member lower section bush bolts, (these shoulder bolts go through cross member bushes)
part number is N903-059-01 (10mm X 73mm long)
cost is £3.84 + VAT per each
4 of these are fitted to cross member = 2 each side.
Front cross member top section bolts, fixes top section cross member to body,
part number is N101-417-01 (10mm X 26mm long)
2 of these are fitted to cross member = 1 each side.
16v engines (KR) and (9A)
have high pressure fuel pump fitted under vehicle,
this fuel pump fits inside the plastic surge tank (pump housing)
The pump is retained by 3 philips screws with flat blunt ends,
part number is N104-047-01
cost is £0.44 + VAT per each
3 of these are used to retain fuel pump.
Also bought a left indicator stork from GSF,
their part number is 933VG0390
Cost is £19.50 + VAT
Hope this helps
Si
Edited by vw rule
Prices below are from my local VW Main dealer
For all Corrado's 16v's, G60, VR6
Rear stub axle bolts, part number is: N908-773-01
Cost is £0.68 + VAT per each
8 of these are fitted, 4 to each stub axle.
These bolts are 10mm X 30mm long
Washers for above bolts, part number is: 321-501-119A
Cost is £0.35 + VAT per each
8 of are fitted, 4 to each stub axle bolt.
For 2.0 16v (9A) but might fit 1.8 16v (KR) also.
Exhaust manifold gaskets, part number is: 027-129-589A
Cost is £12.70 + VAT per each.
4 of these are fitted between head and manifold,
these gaskets are 2mm thick.
I've tried so many of the thinner aftermarket gaskets,
that are 1mm think these cheaper ones don't last 5 minutes, I know the OEM exhaust gaskets are quite expensive, but being 2mm think they normally last for years.
Item below is from VW Heritage,
found the item in their VW Classic Parts search page.
For all UK Corrado's
Rear number plate light unit, part number 535-943-105
Cost is £13.82
Plastic clear one piece lense with rubber seal and bulbs.
Hope this helps
Si
Edited by vw rule
Hello there and welcome to the forum.
I've just ordered a few parts for my Corrado,
and at the same time made some enquiries at my local VW Dealer.
2.0 16v Eng (9A)
Throttle body whole item is now obsolete (was over £1000.00 new from VW) = Obsolete since 2010
Throttle position switch is now obsolete (was £68.00 new from VW) = Obsolete since 2012
(But I'm sure you can still purchase the position switch,
from VW Heritage and off Ebay and possibly from Euro Car Parts)
Throttle body allen key bolts are £1.83 + VAT per each = 4 of these bolts are fitted,
Part number is: N10-073-701
Throttle body gasket is £3.50 + VAT = fits between throttle body & inlet manifold.
All Corrado's
Door handles are now obsolete since 2008
Door handle ruber gasket, fits between handle and outer door skin = gasket is now obsolete
Door lock central locking micro switches are now obsolete
Door lock / boot lock barrel wafer pins and springs are £72.00 + VAT = for a large bag of wafers / springs
(The wafers you use to recode a lock barrel)
(Was told the wafers are the same as the VW van / T4 1990 to 2003)
Hope this Helps
Si
Edited by vw rule
