dkingvr6 0 Posted January 13, 2011 Hello all, has anyone wired these up? Its the combined set that ARZ sell, used to be an option on Corrados, just got some, i have already installed the oil pressure sender (0-10 bar) and fed a wire through to the car interior. Then there has to be a negative and postive to allow the volt meter to work, and finally a light source. All of which appear to go in through a socket on the back of the gauge assembly/pod, is there a plug in the centre consul in the existing loom for this optional extra? Or is it a case of making my own loom up? Cheers Dan Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 13, 2011 need to make something up, early cars seem to have some loom in place for the oil pressure but probably not on the VRs you can take illumination feeds from the cig lighter/ashtray but to get an accurate voltage reading you'll struggle. problem is the feed needs to be switched by the ignition but if you take a feed from an existing loom wire chances are the voltage will have dropped becasue of the old wiring and connectors, only way to do it accurately would be a new fused feed direct from the battery switched through a relay from a switched feed from the ignition, as it would only be a switching feed you could use anything, piggyback off anything that is ON when the ignition is ON. Quote Share this post Link to post Share on other sites
Reggit 0 Posted January 14, 2011 There is a good thread on here somewhere, I found it when wiring mine. But v quickly, you can take the switched live for the voltmeter from the glovebox light and the illumination from the cig lighter. Hereis the info you'll need to wire them. Quote Share this post Link to post Share on other sites
dkingvr6 0 Posted January 14, 2011 Cheers for the answers Quote Share this post Link to post Share on other sites
daavid44 0 Posted January 23, 2011 Heres a few links that might help if you havent already sorted it: http://www.golfgtiforum.co.uk/index.php?topic=102306.0 http://www.clubgti.co.uk/FORUM/showthre ... vdo+gauges http://forum.performancevwmag.com/viewtopic.php?t=37974 Quote Share this post Link to post Share on other sites
dkingvr6 0 Posted January 25, 2011 Cheers for links and info all, as a follow up i tracked the connector part number down that plugs in the back of the gauges, its 1J0 972 704 a flat 4 way connector. I then used female iso connectors in the connector block to give an oem finish to the loom, having piggy backed the live from the glove box light for the 12v for the voltmeter, ran the neg from the earth point above fuse box, the sender wire from the sender (0-10bar) from a t-piece setup on top of the oil filter housing, and piggy backed the light circuit from the ashtray light. All of these were as per the wiring diagram in the Bentley manual. Works a treat i get exactly what the book says on both gauges. Quote Share this post Link to post Share on other sites
iceviolet 0 Posted January 25, 2011 dkingvr6 said: Cheers for links and info all, as a follow up i tracked the connector part number down that plugs in the back of the gauges, its 1J0 972 704 a flat 4 way connector. Found on mk3 golf interior light panel, thats where i got mine from, 50p from scrappers! Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 25, 2011 dkingvr6 said: ... Works a treat i get exactly what the book says on both gauges. so what voltage reading do you get, in my experience there's a lot of drop from the battery (engine running) voltage (approx 13.8V) Quote Share this post Link to post Share on other sites
dkingvr6 0 Posted January 25, 2011 Just checked the voltage on ign on and running ign on: 11.8 Volts (new battery) running: 14.2 Volts hope this helps Quote Share this post Link to post Share on other sites
Reggit 0 Posted January 25, 2011 Mines wired the same way and reads spot on, checked it against a multimeter directly across the battery terminals. After a run I see the voltmeter dropping to around 13v as you would expect as the battery reaches full charge and the alternator regulator output decreases. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 8, 2016 I have my gauges wired up aside from the pressure transducer that I'll fit at a later date. I tested the gauges tonight and oil pressure shot up - is this cos it's based on resistance from transducer? Thanks Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted February 9, 2016 That is correct Chris, if you short the sender wire to ground it will go back to 0 on the gauge Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 9, 2016 Cheers sanky! Will have to get my sender installed soon. Where you been hiding mate? :D Quote Share this post Link to post Share on other sites
Philly-R6 1 Posted February 9, 2016 Bentley Publisers have some interesting information regarding testing gauges: GUAGE AND INSTRUMENT TESTING WITH SPECIAL TOOL VW 1301 Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 9, 2016 Nice! That is getting technical :thumbleft: Quote Share this post Link to post Share on other sites
