Kempy 0 Posted January 21, 2011 do these come off? can I replace it with out replacing the dizzy? thanks Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted January 21, 2011 Yes they do come off but if it's an OEM part it will have glued itself on, easiest thing is crush it with pliers. I've never got one off in one piece! :lol: :lol: Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 21, 2011 what kinda glue? Quote Share this post Link to post Share on other sites
16VG60 0 Posted January 21, 2011 Yes the distributor rotor arm is removeable and can be replaced without renewal of the distributor. Sounds like you have the usual problem of the rotor arm being stuck on to the distributor spindle. To avoid excessive force being transmitted to the distributor spindle by tugging at the rotor arm repeatedly, your best bet is to use a pair of large water pump pliers to carefully crush the rotor arm base attatchment therein breaking the rotor arm away from the spindle. Sounds brutal but if done with care is quick and effective. Before you fit the replacement lightly lube the spindle with LM grease, to avoid same problem next time. Quote Share this post Link to post Share on other sites
