KARMANN 0 Posted February 20, 2004 This is for a MK3 gti.my rado doesnt hav a key fob but i believe the later ones do. On my fathers Golf when he presses the button to open the car the passenger window goes down (say half way) but when he presses the button to lock the car it only goes up to 3/4 shut. Surely this can be reset?any info would be good. Cheers Fraser Quote Share this post Link to post Share on other sites
Phil K 0 Posted February 21, 2004 :?: sounds like it might be a different problem to mine, my window basicly only goes up about 3/4 on auto and you have to go the rest of the way manualy... also does this with the turn key in lock closure and closure on alarm. It doesn't open when I unlock though. Thought it could have been that the alarm needed resetting but not that... wonder if it may need a new module or like you said it may be possible to reset it. Although different problems I would have thought it would be the same module causing this problem... let me know if you get anything sorted and I'll keep you posted if I can sort mine... Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted February 21, 2004 what alarm is it also lock the car with the key and keep the key turnt, the window should roll all the way up Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 21, 2004 Fraser, do the other windows shut all the way? Possibly teh locking pulse is too short. I have the same problem with the drivers window on my MK3. If you arm and disarm the alarm before the thing sets itself fully, the window drops 6 inches. Usually when you forget something and go back to the car, invarialbly its hamering down too! :x I thought it was the alarm, so I fitted another. Same thing happens, chuffing thing. I have been meaning to go into the door cos the comfort window closing doesn't work on that side. I don't know how but it could be related???? Gavin Quote Share this post Link to post Share on other sites
KARMANN 0 Posted February 21, 2004 Yeah Gavin sounds like the same thing here. Basically if my Mother would be patient when she forgets things in the car it would be fine but u know what women are like! The drivers side used to do it-but after about half a hour of pressing buttons and fiddling with keys they were both fine. Now it just seems to be the passengers side that for some reason is opening-atleast if the drivers side done it she would notice and close it. Came up the drive wrecked the other night had wee look at Raddo then noticed the Golfs window was wide open! Begining to think perseverence with reminding my mother is the only solution! Cheers Fraser Quote Share this post Link to post Share on other sites
