KARMANN
Different Windows thing.
Ok when i first got my rado i could stick my key in the door turn it and hold it there and the window would open-likewise if i turned it the other way it would shut- but now it doesnt do anything-any ideas?
Cheers Fraser
If your central locking still works okay, it sounds like a fuse/relay problem. Not sure which relay it is but there will be a "closure" relay fitted - maybe near the fusebox with the rest of the relays.
Have you had an alarm fitted or ANY other electrical work done recently ??
Well,around a year ago when i got the car i got a cat 1 imob fitted. Then the drivers door handle broke. So i had all the inner door card & lining off.
Sounds silly but fcukn hurt-i was driving out of B&Q pressed button for window to go down got my hand traped between window going down and door-the switch fell between window and the door,i couldnt reach it. Thought i was going to lose my hand! Had to shout for a passer by to take the keys out ignition and do the door thing!
Thats the last time i remember using it. I havnt had anthing else fitted or changed so il look into the fuse relay area.
Cheers Fraser
Cheers Fraser
Maybe one of the wires inside the door has become loose/detatched ??
So there's a relay that controls the closure system... is it possible for a faulty relay to only open / close the window by about 75%? might help solve my problem too 8)
