Rams 0 Posted February 11, 2011 (edited) What type of screw/bolts hold the sunroof switch trim in place? Also, the seats belts, how close is the metal bracket to the slider? Is it just one large bolt or a washer? I have so many bits that im trying to piece together. Vagcat is down for some reason and dont know who else I can bring up pictures or slide shows? Any help would be awesome. Any ideas what the shim style bits are for? I do feel like a prat as I didnt organise myself but I didnt strip the car fully so cant remember where it all goes. My staff member taken off a job to help me! Edited February 11, 2011 by Rams Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 12, 2011 The sunroof switch cover is held in by 2 gold phillips bolts, cant remember how long but not very long! (Novastrike an ex corrado owner used a bolt too long and put a hole in the roof!!) Shim style bits are for the 'oh sh1t' passenger handle Long (about 15/20mm) block hollow bits with a lip go through a hole at the top of the B pillar trim IIRC Will get back to you about the last few bits Quote Share this post Link to post Share on other sites
Rams 0 Posted February 12, 2011 Top man! The parts with the pads are for the bonnet, they are in now, the 3 right hand items are now in place, the small round sleves might be for the rear parcel shelf to hold the rubber stays??? The shim bits, I see, the jesus handle as it often referred to! I would never have worked that out although, IU havent fitted the handle yet! Sunroof bolts in. The 2 rubber stoppers, I have large ish ones in the tailgate and 2 large ones in the bonnet, so not sure where elese these go? Do the doors have stoppers? Honestly, thanks for this, I have been quite stressed out putting the car back together but 95 percent there now. Quote Share this post Link to post Share on other sites
