v8rumbler 0 Posted February 22, 2011 Tried to clear the front screen today but water did not emerge yet the pump was running. The fluid was only making it so far along the tubes. When I tried the rear that too was not working but I did get water emerging from the plastic hatch trim panel. I discovered the plastic pipe which goes through the rear wiper is broken--- but would this account for the fronts not working? when the pump runs how does it know where to send the water? I am assuming that if the rear pipe is 'open ' then there will be insufficient pressure to wash the fronts!!! Darren Quote Share this post Link to post Share on other sites
quicky1980 0 Posted February 22, 2011 i dont have the rear connected anymore but if i remember correctly the pump has two connections. one feeds the front and the other feeds the rear. when activating the pump via the dash its makes the motor rotat one way or the other to direct the flow to the relevent area. there should be plenty of pressure to feed the front, have you followed the pipe from pump to both washer jets..any breaks? If not maybe the jets are clogged or the pump is tired/bust? Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 22, 2011 bet you have been polishing it again darren ,lol bet the jets are blocked . Quote Share this post Link to post Share on other sites
stereoflaver 0 Posted February 23, 2011 I had very poor flow out of mine, just a girlie dribble. I removed mine and steeped them in boiling water for a few minutes then blew them out with compressed air. Now there like new. Quote Share this post Link to post Share on other sites
v8rumbler 0 Posted February 24, 2011 Well Mine had a non return valve -probably non original but either way it was 'non returning' in both directions. --All is now good!! Quote Share this post Link to post Share on other sites
v8rumbler 0 Posted February 24, 2011 bet you have been polishing it again darren ,lol bet the jets are blocked . Cheeky get ! Not washed either of them all year Quote Share this post Link to post Share on other sites
Peebee 0 Posted February 24, 2011 Mines playing up, turns out the pipe kinks in the corner restricting flow. Quote Share this post Link to post Share on other sites
