Rocket Ron 1 Posted March 15, 2011 Anyone fitted any day light led lights yet. Quote Share this post Link to post Share on other sites
mr.ots 10 Posted March 15, 2011 I don't think they look right on older cars, can't honestly see the point either. Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted March 15, 2011 Aren't they going to be mandatory soon..? Quote Share this post Link to post Share on other sites
jacko 0 Posted March 15, 2011 aparently they already are mandatory since last month but only on cars registerd after feb 2011 LEDs look silly on older cars imo, i was thinking about maybe putting a sidelight bulb on the outside edge of the front indicators as DRLs Quote Share this post Link to post Share on other sites
nlau1 0 Posted March 19, 2011 YOu can have DRL's that aren't LED's. My mums 6R Polo just has the front headlights on (only fronts, not rears) at all times. Maybe its possible to wire the Corrado headlights to do the same? Only problem with this system is that its very easy to forgot to turn the lights on at night as the fronts are on as soon as you start the car! Quote Share this post Link to post Share on other sites
RW1 0 Posted March 20, 2011 I've been using these for years as a sidelight replacement. Bright as dipped beam being on and illuminating the whole headlamp brightly. [ATTACH=CONFIG]45546[/ATTACH] . Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted March 23, 2011 Its become mandatory - is this another copy what ever Europe is doing? whats the point exactly? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 23, 2011 My mums 6R Polo just has the front headlights on (only fronts, not rears) at all times. Maybe its possible to wire the Corrado headlights to do the same? Sides or dipped beam? Easy way is to cut the relay signal on sockets A1 (nearside) and A2 (offside) and run straight off the ignition instead of the HL switch, which takes care of the rear light issue. Neater and trickier way is a modified headlight switch. Quote Share this post Link to post Share on other sites
nlau1 0 Posted March 23, 2011 Sides or dipped beam? Easy way is to cut the relay signal on sockets A1 (nearside) and A2 (offside) and run straight off the ignition instead of the HL switch, which takes care of the rear light issue. Neater and trickier way is a modified headlight switch. Sides and Dipped beams, and dials on all the time. Quote Share this post Link to post Share on other sites
