adaptorman
mk1 golf caddy pickup 4wd/vr6turbo ,r32 turbo,transplant
hi all ive currantly done a build on my mk1 caddy adding 4wd ,electric steering, leather seats,dash ,sunroof,conversion,along with side pipe exit,6speed 02m,gearbox ,5 paddle cermic clutch, 640cc injectors hx40 turbo, 46mm wstegate,scremer pipe,with lots of homemade parts ,
ill start what ive currantly built fitted
5n92jl.jpg bingo holding 30psi
lastist engine shot
2wm2nix.jpg evern thow its runing well i personaly wont to start over with ms3 standalone ecu as it should be a better set up and live tuning too
loves eating bmw m3s,scoobys and evos ,lol
next the new engine mk5 r32 tt engine
so far stripped the lump , added a mk4 r32 forged crank to safe
headspacer,8,5.1
modifyed some 530cc injectors,
made a alloy welded manifold
modifyed a mk5 fuel into a mk4 style
rewired the engine for ms3x and vvt wired up
added ls2 coils
trail started on the floor
ive got the gearbox in bits changeing ratios at mo,
then need to make a exhuast turbo manifold
then add hx40 turbo
quick pic
added a little leaf blower
quick pic of the new ecu ms3x megasquirt runing on yuko ls2 coils
new manifold arrived arrived and thought id do a trail fit ,all seems good,,,..but hit a issiuse
didnt realise these manifolds are for t25 turbos , and mines a t3 ,, sdue to were external wastgate is shown, its in the wrong place , so that turbo intake is wrong way as well ..
so bit of adapting is needed first manifold
then chopped t25 flange off and welded a cast t3 flange on along with ,moving external wastegate too
notice now the intakes on the left and not on right ,
notice were old wastegate is now , ill just make a blanking plate , so then manifold can be used both ways
trail fit time
fits good , also i can now not only fit a turbo either way , but also spin the intake snail 360deg for any pipe angle ,,
next stripped r32 gearbox and adding tdi ratios for better cruiseing ,
question im not 100percent on the external wastgate as itsa 38mm? anyone really know how mutch boost i can run before boost creep
impressive work there - all your own? Keep the pics and details coming and it would be interesting to see some performance figures or videos.
Ummmmm WOW, I like I like I like
That will be one hell of a monster once finished
Keep the pics coming
yep al my own ideas, tbh the mk3 vr6 currantly fitted has fully forged pistons, rods, the r32 hasnt , but r32 should flow better and feel better with vvt working on the ms3 ecu, its not massive performace but mk5 should hold between 15/20psi max ,if all works out well, ive not seen many mk5 , only mk4s , i hit a small issiuse with fuel line as i couldnt find a mk4 r32 one so adaptored this to this,
---------- Post added at 09:19 AM ---------- Previous post was at 09:16 AM ----------
other things i need to do is make a alloy feul tank for the rear ,/some pipework for exhaust/ alter a few boost pipes , nothing too techical im affraid
Nice one! This is my kind of thread :D
Good work on the turbo manifold, I guess that's why they call you the "adaptor man" :D
Is that the SPA turbo mani? I looked at that for mine but didn't like where the wastegate was positioned. I thought the SPA used a T3 flange though? T25 is useless for a 24V!!
Looks like one to watch for sure.
Would like to see a few more photos of the caddy. Is it Syncro, Haldex or a mashup of the two?
