VR-Sixy 0 Posted June 8, 2011 After a very minor shunt, need a new complete nearside spot/indicator fitting. This is for a 94 VR6 so it's the later fitting with the two lights in the one housing. Paypal button waiting to be hit........ Cheers Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted June 8, 2011 Hi there, I have the indicator. Yours for £20 posted if that helps? Thanks, Neal. Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted June 9, 2011 Hi there, I have the indicator. Yours for £20 posted if that helps? Thanks, Neal. Hi Neal, really need the spot as the glass is smashed on it. The indicator escaped any damage at all. I thought the later spots/indocator where all complete in one housing or can you remove the seperate components? Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted June 9, 2011 The indicator pops out separately. Ian. Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted June 9, 2011 The indicator pops out separately. Ian. Does the spot do the same thing? Quote Share this post Link to post Share on other sites
87 Jetta 16v 0 Posted June 9, 2011 Hi there, The spot makes up part of the housing. You might be able to change the lens, though I am not sure, I think it is bonded in. Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted June 10, 2011 Hi there, The spot makes up part of the housing. You might be able to change the lens, though I am not sure, I think it is bonded in. Doesn't look like you can. Think i'm going to have to replace the whole spot unit. Quote Share this post Link to post Share on other sites
dragon green 4 Posted June 10, 2011 You can buy the lenses separate, about £50 a pair ! Check out the suppliers forum. Quote Share this post Link to post Share on other sites
