jd89 10 Posted June 15, 2011 Right guys I've been looking about but can't find it!!:-( can someone please tell me where the engine speed sensor is located please....:-) Photos would be appreciated!:-) Thanks Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 15, 2011 What sort of car do you have?? On the VR6 there is a Cam sensor (on non dizzy models) , a crank sensor (known as the Vehicle Speed Sensor) and one on the gearbox that feeds the speedo. Quote Share this post Link to post Share on other sites
easypops 8 Posted June 15, 2011 It might help, just a little , if you were to give a clue to what engine it is? :lol: Lol too slow Quote Share this post Link to post Share on other sites
jd89 10 Posted June 15, 2011 Sorry...it's a vr6 93!! It had diagnostics on it and came up with 3 faults.... Maf...been replaced Engine speed sensor or the lambda so I'm starting with the engine sensor first. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 15, 2011 Sorry...it's a vr6 93!! It had diagnostics on it and came up with 3 faults.... Maf...been replaced Engine speed sensor or the lambda so I'm starting with the engine sensor first. Whats the problem with the engine? was it scanned with the engine running? Quote Share this post Link to post Share on other sites
jd89 10 Posted June 15, 2011 It has problems at idle and then cuts out but drives fine, engine wasn't running when it was tested Quote Share this post Link to post Share on other sites
Dox 23 Posted June 15, 2011 It has problems at idle and then cuts out but drives fine, engine wasn't running when it was tested Clean the throttle body and check for air leaks would be my first port of call. Quote Share this post Link to post Share on other sites
jd89 10 Posted June 15, 2011 I have already cleaned the throttle body out and done the isv, what else can I do? Quote Share this post Link to post Share on other sites
vr6storm v2 10 Posted June 15, 2011 engine speed sensor always comes up when scanned while not running Quote Share this post Link to post Share on other sites
jd89 10 Posted June 15, 2011 Waste of time changing it then?:-( Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted June 15, 2011 Waste of time changing it then?:-( Scan with engine running, doesnt hurt to give cam position sensor and ISV valve if your having stalling issues. Quote Share this post Link to post Share on other sites
jd89 10 Posted June 15, 2011 What shall I do with the cam and isv!? Give them clean out? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 15, 2011 Post the codes up.. Quote Share this post Link to post Share on other sites
jd89 10 Posted June 15, 2011 553 limited 537 limited 513 no signal Quote Share this post Link to post Share on other sites
