luke w 0 Posted June 20, 2011 Am I right in thinking the door gaps can be adjusted? Both doors have fairly large gaps at the moment with a fair bit of wind and road noise coming through. Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 20, 2011 not really, front wings have a bit of movement but the doors are basically fixed position, most of the poor fitting doors I've seen are due to damage. Corrado doors seem to twist out of shape easily around the glass frame and that leads to sealing problems. I've not needed to change the hinge pins or adjust the doors even on my 21 yr old Corrado, but then I don't lean on the doors when they are open. You may be able to shim the doors back a bit towards the B pillars on the hinges but I reckon your problems are still down to out of shape door frames and not the door position. Quote Share this post Link to post Share on other sites
luke w 0 Posted June 20, 2011 It's not between the wing and door and the b pillar and door where the gap is, it's more like they aren't closed properly. If you look down the side of the car from the rear quarter panel the doors stick out a bit. I'm sure I've read somewhere you there's a bit of adjustment for this. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 20, 2011 Striker pins on the B pillar. 15mm ring spanner best. The reason they are adjust more outwards usually is because the doors need a harder slam to close when pulled in to get tight shut lines. Quote Share this post Link to post Share on other sites
luke w 0 Posted June 20, 2011 Thanks, I'll give that a go tonight and see how I get on. Quote Share this post Link to post Share on other sites
