Mystic Storm
2.8 VR6 (24v) Injector
Hi,
I've been having a few problems with my rado (has the 24v 2.8 conversion from a 4mo) recently and after several visits to my VW specialist they've finally decided that one of the injectors needs to be replaced. It's been down on power for a while with a bit of a flat spot. They changed the fuel filter, pump and relay and tried a new MAF etc but nothing has worked. The fault on the diagnositics is the solenoid valve and there are no faults with the relays for this.
Anyway, the guy I deal with is struggling to source an injector. Part number is 022906031. Can anyone help?
Cheers,
James
Hi I did have a fuel rail with these in. I see if I have them still. wouldn't want to split a set so if your interested in a set of spares let me know
Doug
Doug
Cheers man. How much you looking for the set?
