Rams 0 Posted July 11, 2011 Having troubles taking the bottom 10mm nut off the threat that holds the materix to bulkhead. I've tried wd etc, but it just keeps spinning. I understand a few people have struggled with this nut. I have the dash out ready to replace with my re trimmed one, wires everywhere and I just wanted to replace the matrix for piece of mind. The foam that sits around the wires behind the dash, some of it just crumbles away, is this foam wrap readily available or any ideas what I could use? Or should I just tape them up with loom tape and not bothere with the padding that has seen better days... Quote Share this post Link to post Share on other sites
dragon green 6 Posted July 11, 2011 The bolt can be cut off ! Repairing it is easy when the heater box is out. This should help your foam dilemma http://the-corrado.net/showthread.php?p=729260 Quote Share this post Link to post Share on other sites
Rams 0 Posted July 11, 2011 Cheers for that, most helpful Quote Share this post Link to post Share on other sites
