Redfox 10 Posted September 11, 2011 Hi all, I just put on a second hand headlight, as one was cracked in the glass. So all is good, and too a trip. When returning home, I noticed less light in the garage, looking at it, it was covered inside with water/steam/? What to do? Are they prone to let in water? The light I bought had been lying a few years in a wet barn, so this could just be a simple matter of bulps out and ventilate. Anyway I took the bulbs out and tried a little heatfun, and let them sit for a while. I will have a look later tonight. Still, I wonder if it can be made tight again, if there isa leak? Cheers, Redfox. Quote Share this post Link to post Share on other sites
dragon green 5 Posted September 11, 2011 There is a gasket between the glass and headlamp,its still available from the dealers ! it might just be condensation from were its been sitting. Quote Share this post Link to post Share on other sites
carrots 1 Posted September 11, 2011 i put a bit of clear silicone around the gasket on mine Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted September 11, 2011 hello, while were on the topic of headlights, are they easy to remove? just the skrews on the clips on top? then unplug? also can the glass be seperated from the main body? thanks... Quote Share this post Link to post Share on other sites
dragon green 5 Posted September 11, 2011 hello, while were on the topic of headlights, are they easy to remove? just the skrews on the clips on top? then unplug? also can the glass be seperated from the main body? thanks... this should help http://wiki.the-corrado.net/headlight_lens_replacement.html Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted September 11, 2011 this should help http://wiki.the-corrado.net/headlight_lens_replacement.html thanking you! thats perfect Quote Share this post Link to post Share on other sites
