Redfox
water in headlights?
Hi all,
I just put on a second hand headlight, as one was cracked in the glass. So all is good, and too a trip. When returning home, I noticed less light in the garage, looking at it, it was covered inside with water/steam/?
What to do? Are they prone to let in water? The light I bought had been lying a few years in a wet barn, so this could just be a simple matter of bulps out and ventilate.
Anyway I took the bulbs out and tried a little heatfun, and let them sit for a while. I will have a look later tonight.
Still, I wonder if it can be made tight again, if there isa leak?
Cheers,
Redfox.
There is a gasket between the glass and headlamp,its still available from the dealers !
it might just be condensation from were its been sitting.
hello, while were on the topic of headlights, are they easy to remove? just the skrews on the clips on top? then unplug?
also can the glass be seperated from the main body? thanks...
