quicky1980 0 Posted October 5, 2011 Which is the best one to buy to help remove a number of spot welds? I dont want to waste money on one they will wear out quickly or break but also dont wish to spend a fortune. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted October 5, 2011 How much is a fortune to you? You should be able to pick up a HSS titanium drill bit for under 10 quid which will do the job just fine. Quote Share this post Link to post Share on other sites
quicky1980 0 Posted October 5, 2011 ive seen some on the bay go for £80 each, thats what i consider a fortune. So would you say a tenner is a decent item? seems a bit too good to be true :shrug: Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 5, 2011 http://www.google.co.uk/products/catalog?hl=en&cp=15&gs_id=19&xhr=t&q=titanium+drill+bits&rlz=1R2ADFA_enGB412&biw=1024&bih=577&gs_upl=&bav=on.2,or.r_gc.r_pw.,cf.osb&wrapid=tljp1317846799169014&um=1&ie=UTF-8&tbm=shop&cid=4426823258503880595&sa=X&ei=EL-MTuHGCI210QWSn53UBQ&sqi=2&ved=0CIIBEPMCMAI# Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted October 5, 2011 If you punch into ebay spot weld drill, there is loads, but if I was you I would pay about £20 for one, and get Cobolt one as it will last longer. HSS drill bits don`t last as long, Or if you are feeling rich, see if you can find a Carbide tipped drill, stay sharpe and last ages. Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted October 5, 2011 I have always used normal drill bits, that way if they snap then it doesn't matter. Usually when they snap its down to the operators fault. The part thats tricky is sharpening them properly if you have a grinding stone and the ability to sharpen them properly then I would go for low cost ones. Quote Share this post Link to post Share on other sites
quicky1980 0 Posted October 6, 2011 thanks guys, didnt realise they had different sizes. Any idea which size I should go for? Trying to take the spot welds out of the boot floor pan ---------- Post added at 04:39 PM ---------- Previous post was at 04:37 PM ---------- oh and came across spot weld cutters/removers, are these better than the drill bits? Quote Share this post Link to post Share on other sites
Timbo 0 Posted October 6, 2011 If the back panel isn't going to be used I would just drill straight through with a normal drill bit. I've used the spot weld drills in the past and they go blunt very quickly. They're also a PITA to sharpen. So if you're not keeping the boot floor don't waste your time, just go through both panels. Quote Share this post Link to post Share on other sites
blue95 0 Posted October 7, 2011 Dont bother with spot weld cutters, expensive and fidgety......just get a good quality metall drill bit HSS carbon or whatever it is. Stop regular and lube with machine oil, you will drill through for a while, after a bit you well get a feel for the metal and you will surprised you can sense when you can have gone through just enough metal to split the panels. Also worth having a flat chisel and hammer too! Dont worry about making too much mess holes can always be filled! Quote Share this post Link to post Share on other sites
