chrisspencer 10 Posted October 25, 2011 Hi, A bit puzzled, drove my VR down to work on sunday with no problems running fine, then came to drive home about 2 hours later and it wouldnt start. I was a little low on fuel but other than that nothing noticeable. Since I have put a jerry can full in and even tried a bump start but nothing. Seems to be a spark and smell fuel getting through. The car is turning over but doesnt sound like its even trying to fire... Had hassle with the after market immobilizer in the past but the car usual starts and cuts out immediately when its that. The only thing i can liken it to is just after i brought the car the crack sensor failed and the car did exactly as above. However i had the sensor replaced in march. Had a scan with vagcom i've recently brought and it came up with the following- Address 01: Engine Labels: 021-906-258.LBL Controller: 021 906 258 CP Component: MOTOR 2,8L 6-Zyl. Coding: PMC 1 HS Shop #: 0261203565 VCID: 64BB2F93E755 No Faults Found or DTCs not supported by controller or a communication error ocurred I dont think thats any help mind..? Any help would be much appreciated :) Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 25, 2011 Have a look through the search for non starter , had loads of help with mine , turned out to be dirty ecu plug . Quote Share this post Link to post Share on other sites
chrisspencer 10 Posted October 25, 2011 Cheers, I'll have a look now Quote Share this post Link to post Share on other sites
