Critical_Mass 10 Posted November 2, 2011 Hi all, Noticed some spots (dunno why they've come up in half a dozen spots) of laquer peel on my bonnet. Short of getting it repainted. Is there anything i can do to sort this. Possibly rub it down with some fine wet and dry and respray and buff? Is that optimistic of me? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 3, 2011 Yep, peel the dead paint back as far as possible then fill in the void with new laquer, then sand / buff flat again. Simples! Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 3, 2011 Post a pic of your peel, I got some and wanna see if its fixable Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 3, 2011 Cool. What grade paper are we talking, 2000grit? Ryan - i'll try get some pics, but wont be until weekend as its dark by the time i get home Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 3, 2011 2000 is a bit extreme! 1200 should be fine, with some water. Then when the new and old paint are seemlessly flatted in, you can then get the polish out. I quite like G3 compound myself, but even Autoglym cutting polish or T cut would work, which are easier to get hold of (Halfords). Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 3, 2011 Cheers fella, appreciated. Want to get these sorted before they get worse - they're only small at the mo. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 3, 2011 Yeah I've got one on my driver's mirror to do, so I'll be following my own advice soon :D After many years of patching up old cars, this is the best laquer I've used to date - http://www.autopaintsbrighton.co.uk/u-pol-clear-1-high-gloss-clear-coat-lacquer-450ml-aerosol-1422-p.asp I think Halfords sell it as well. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 3, 2011 Then i will try the recommended laquer. Cheers Kev. Hoping i wont make it worse! haha. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 15, 2012 (edited) Right managed to finally get this started. so far ive feathered the edges of the peel and put 4-5 coats of laquer on. But its a very dull, rough finish... will this be ok once i get some cutting compound on it? sorry Ryan i forgot to get some pics of the peel. To be honet you can still see the patches now, but at least the paintwork is now sealed and not open to the elements. Still as long as it lasts until i can get a front end respray done. Edited July 15, 2012 by Critical_Mass Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted July 17, 2012 you will have to wetsand with 1500-2000 then cut n buff that dull rough finish, btw the way you have done this you will allways see the patchs where the clear coat peeled off, the only way to make it an invisible repair is to feather the edges back like you did but then you would re base and blend out with basecoat {the cars colour} and then re clear the whole panel/ bonnet in one go so it seals it all in, basecoat {the cars colour coat } doesnt get sanded at all, if you sand an area of basecoat it looks different when the clears put on top and basicaly that area sticks out, and thats the reason them patchs where the clear peeled off will allways look different, even if you had a bodyshop spray the clearcoat them areas would still look different, also another factor to take into consideration is UV breakdown , modern clearcoats stop fadeing and with the clearcoat being gone in that area it would of been affected to some extent by UV .. Quote Share this post Link to post Share on other sites
