24V Renshaw 0 Posted January 5, 2012 They are due to be delivered next week. I will chase them up and make sure that is still the case. Cheers Jay Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted January 6, 2012 24V Renshaw said: I am afraid that's it for this set. If I get enough interest I could run a second lot... I could start a list I guess... I'll step back and let someone else have mine if they want. I have made this offer to Volksworld13 and am waiting to hear back. Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted January 8, 2012 4eyes2wheels said: I'll step back and let someone else have mine if they want. I have made this offer to Volksworld13 and am waiting to hear back. Anyone? Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted January 10, 2012 Just checked with the poly supplier and the mounts are due to get to me Friday latest :) So I will box them up and send them out as quickly as I can. Jay Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted January 10, 2012 Cheers for the update mate Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted January 19, 2012 They are here!! Going to pack them up tomorrow and get them posted ASAP. Cheers Jay Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted January 19, 2012 Yay! Thanks mate :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 19, 2012 Would love to sniff your box Quote Share this post Link to post Share on other sites
dghodges 0 Posted January 24, 2012 4eyes2wheels said: I'll step back and let someone else have mine if they want. I have made this offer to Volksworld13 and am waiting to hear back. I'll take them if you don't want them and Volksworld13 doesn't want them? Cheers Quote Share this post Link to post Share on other sites
robo22sri 10 Posted January 24, 2012 Have these been posted out yet? Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted January 24, 2012 dghodges said: I'll take them if you don't want them and Volksworld13 doesn't want them? Cheers 24V Renshaw has refunded me so you will need to contact him to see if they are still available. Quote Share this post Link to post Share on other sites
dghodges 0 Posted January 24, 2012 4eyes2wheels said: 24V Renshaw has refunded me so you will need to contact him to see if they are still available. Jay, Have you got any sets left please? Cheers, Dave Quote Share this post Link to post Share on other sites
stu37 0 Posted January 25, 2012 Hello mate in after a rear one have you any left? Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted January 27, 2012 Apologies for the delay in updates on this. Had to go away for work and have only just managed to post the mounts. Even took a pic of one at the post office :) So look out for the postie with a heavy cardboard tube! Jay Quote Share this post Link to post Share on other sites
aide 0 Posted January 27, 2012 Cheers for update Jay, look forward to posty arriving :) Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted January 27, 2012 I need to post up a fitting guide on here so when they arrive you all know what the bits are :). Will do it over the weekend. Jay Quote Share this post Link to post Share on other sites
iR6 0 Posted January 27, 2012 24V Renshaw said: Apologies for the delay in updates on this. Had to go away for work and have only just managed to post the mounts. Even took a pic of one at the post office :) So look out for the postie with a heavy cardboard tube! Jay Woohoo! That's my one just there! Thanks very much for sorting Jay :) Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted January 29, 2012 Figured that now the mounts have been shipped I should put up a basic how to fit them guide. Put simply the red poly bits you will receive replace the black rubber bits in both the front and rear mount. First job is to remove the existing mounts to fit the new inserts. The rear one is the most complicated so we will start there. First off you need to remove the heat shield over the mount if you have it by just removing the push fit metal clips. Once the heat shield is off, undo the two 13mm bolts on either side of the mount and the 13mm nut on the top holding the lambda sensor bracket. These are all easily reached by using a long extension on a 13mm socket from up above the engine. Once these are undone and the bracket is out of the way you can undo and remove the 17mm bolt in the centre. Next you need to lift the back of the engine as high as you reasonably can, this will lift the engine away from the mount enough to simply wriggle the mount out. You can choose how you lift the engine up, but make sure you pick a solid point and as close to the back corner as you can. So you now have the mount out and ready to dismantle. First job is to bend back the tabs, use a big old screwdriver for this. Once these are back the two halves of the mount come apart. Now you can see the existing lower rubber part of the mount, remove the cap head bolt from the mount and you will now be able to access the upper rubber part. Remove the existing part and replace it with one of the two larger parts in the kit. I put some copper slip on mine but I don't think it's really needed. Then you can refit the plate and fit the larger diameter (80 odd mm) of the two thin mount parts to it. Then fit one of the two metal discs in the kit along with a washer and one of the new cap head bolts supplied. Once fitted you can refit the lower housing by bending the tabs back again. Refitting in the car is reverse of removal, but use the two 13mm bolts supplied to bolt the mount back to the subframe. Also make sure the tabs on top of the mount are lined up under the metal bracket on the engine. Your all done for the rear mount. I will post up the front mount one in a bit. Jay Quote Share this post Link to post Share on other sites
UseOnceDestroy 0 Posted January 29, 2012 Excellent guide! Looking forward to struggling with this... Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted January 29, 2012 It's easy honest :) OK so on to the front.... First off remove the 17mm bolt from the top, easily accessed down behind the radiator. Then remove the cover from under the mount on the underside of the crossmember. This leaves the lower part of the mount visible. Undo the 8mm cap head screw and remove the lower part of the mount. Once this is removed you can jack the engine up and wriggle the upper section of the mount out. With this out remove the old rubber section and fit the new poly piece. Again I used copper slip, but not essential. Once done refit the upper part of the mount back into the crossmember and lower the engine back down, this will allow you to push on the smaller lower mount part. Then just bolt on the washer and metal disc with the 8mm cap head bolt supplied and refit the cover. All done. Quote Share this post Link to post Share on other sites
UseOnceDestroy 0 Posted January 30, 2012 Mine have just arrived cheers mate!! Weeeeeeey Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted January 30, 2012 Mine just arrived. Thanks very much Jay! I will be waiting for warmer weather before I fit them. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted January 30, 2012 Glad to hear they are starting to arrive :) Jay Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted January 30, 2012 Cheers for the guides... mine have arrived so cheers for that too!! Quote Share this post Link to post Share on other sites
