pettsy
Breaking 1992 Corrado 2.0 16v - Prices Lowered To Clear!
Now down the remaining bits, shell has been scrapped. The list below is what i've got left, which im looking to clear as soon as possible. Im open to offers on most bits,would rather sell them cheap than leave them sitting on the shelf in the garage!
Im happy to post parts out at the buyers expense, but prefer collection from me near Matlock in Derbyshire.I can be contacted via mobile on 07944 884008, if no reply leave a message and i'll call back when i can!
Head - £40
Grille Spoiler - £10
ABS Switch - £20
Front Brakes - £30
50mm Splitter - £20
Power Steering Pipework (full set apart from hardpipe that attaches to front crossmember) - £20
Gearbox - £70
ECU - £25
Front Wiper Motor - £10
Rear Wiper Motor - £10
lift pumps - £15
Wiper/Ind Stalks - £10
Radiator Fan (twin speed) - £20
Vibratechnics Front Engine Mount - £60
Lower windscreen scuttle trims - £10 (no clip fittings,were just stuck on)
Electric Window Mechs - £20 each
Fuel Tank - £20
Central locking pump - £20
Throttle Body - £20
Fan control relays - £15
Header Tank - £10
Radiator Hoses - £offers
Alternator - £20
Starter - £20
Power steering pump - £20
Inlet Manifold - £40
Plastic Top radiator cover - £5
All prices plus postage
Edited by pettsy
Updated remaining parts/prices
Does it have dials or sliders for the heaters, if dials how much delivered as long as they are fully working with no broken off bits?
Does it have properly working ABS? I would be interested in the pump, ecu/controller, master cylinder and as much of the wiring loom as possible (although i do not need the sensors).
Abs is in full working order as far as i can tell (light goes out correctly and no strange noises when braking etc)
  pettsy said:
Have just removed the dials for the heaters,unfortunately one of the clips that holds the cable in place on the back is broken.
Can you take a photo please and how much delivered as spares or repairs?
Edited by Rustynuts
punctuation
  Metallix said:
Pettsy, if it's got one, I need the ABS position sensor off the servo, below the master cylinder
Cheers matey
Im not sure if markg60 needs this along with the other abs bits?
  rodmax said:
Hi , i may need the engine ecu,how much do you want for your one
thanks rod
£30 plus postage
  ben_wooduk said:
How much for the passenger front hub?
£30 collected
To be fair Mark never mentioned that he wanted the servo, master cyl yes, servo no.
Need that part to fix an immobile car
  Tooand said:
Hi mate will take the grill spoiler also I'm after a drivers door weather strip if you've still got it
which bit do you mean by weather strip? Grille spoiler is here still, would prefer collection on it if im honest
Hi pettsy the weather strip is the two strips on the door either side of the glass, does that make sense
Alright pettsy,
Could I have the air filter box through to the air inlet manifold (basically the air box and everything that goes on top of it) if you would.
I only live over in Stafford so could pop over at the weekend
Ta. george
