VeeDub_NZ 0 Posted November 16, 2011 Do I need a facelift bonnet if I'm putting a 24v in? I am about to rip into the conversion but if I NEED the facelift bonnet I want to make sure I have it before kicking into it. Cheers Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 16, 2011 (edited) Yes Or do what MK2 24V convertees do and chop the engine mounts down. Depends on the 24V in question too because the MK5 R32 needs less head room than the other 24Vs. Edited November 16, 2011 by Kevin Bacon Quote Share this post Link to post Share on other sites
quicky1980 0 Posted November 16, 2011 i was under the impression that all r32's are fine with early bonnets but the 2.8 24v's arent Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 17, 2011 The engine trims are usually what causes clearance issues, but the MK5 engine doesn't use them. Jay had to cut a support brace out of his bonnet to fit the 2.8's engine trims and I think that was a late bonnet too. AFAIK, all MK2s and early Rado bonnets cause clearance issues with any 24V, hence the engine mount chopping. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted November 17, 2011 The late spec bonnet only has a positive bulge to allow for more soundproofing to drown out the awful chain jangle of the VR6. :lol: ;) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 17, 2011 And there starts the kinky chains or rubber debate.... Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted November 17, 2011 I did indeed flush one of the braces from the underside of my bonnet when I did the 24v conversion, but this was only to allow the use of the engine cover to retain the OEM look. Most conversions don't use the engine cover, or at best use the small old type cover. Quote Share this post Link to post Share on other sites
coullstar 0 Posted November 17, 2011 The sump on mine sat low so chopping mounts will make it lower still. Get a bulge bonnet or try and get a Mk5 R32 sump and pump. Quote Share this post Link to post Share on other sites
VeeDub_NZ 0 Posted November 21, 2011 It's a 2.8 24v (BDE) out of a mk4 bora V6 4 Motion. So you guys reckon that my early bonnet should clear the motor fine if I cut the mounts down a bit and run a mk5 R32 sump? I was looking into one of those anyway because it sits quite low and don't want to risk it. Ideally I'd use the bonnet I have, it'll cost me near on $1,000 by time I get a facelift one imported! Quote Share this post Link to post Share on other sites
