Tooand 10 Posted November 19, 2011 Bought a set of amber LED indicator bulbs as I'm going to tint the rear lights red, but when fitted they flash like I've a bulb out, I'm guessing this is because the use very little power and the car can't detect them or I could be way off. Anyway, how do I cure this little problem pls Quote Share this post Link to post Share on other sites
leon263 0 Posted November 19, 2011 The LED bulbs have a very low resistance and you will need to wire in resistors to rectify the problem. Do a search on e-bay for 'LED bulb resistors' and you will pick up a pair for around £6. Scroll down through the post below and you will find pictures showing the wiring required. http://the-corrado.net/showthread.php?58695-Ben_Wooduk-s-Black-Corrado-VR-Number-3 Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 19, 2011 They are normally quite long and white. Mine are anyway. Quote Share this post Link to post Share on other sites
fla 9 Posted November 19, 2011 get the ones with the external heat sink - more expensive but worth it . I may have a spare set with the spades still on them so you just have to plug them in. Will check and let you know. Quote Share this post Link to post Share on other sites
Tooand 10 Posted November 19, 2011 fla said: get the ones with the external heat sink - more expensive but worth it . I may have a spare set with the spades still on them so you just have to plug them in. Will check and let you know. Thanks for all the help lads, Fla that would be great, cheers Quote Share this post Link to post Share on other sites
