mjcp 0 Posted November 22, 2011 Can someone explain what the heater fan resistor does? Last time I had mine out, I stuck the multimeter on it expecting to find resistance readings that vaguely matched to the figures written faintly on the green wrapper. Instead I got figures that simply varied and there was continuity etc between most pins. Is this a "Ballast Resistor" that varies resistance with current or is mine just knackered? I am assuming that the higher resistance is for the lower fan speeds, hence it gets hotter on lower speeds which is why the thermal fuse dies...? Lastly, this is the same method of running heater blowers as loads of other cars use (see eBay etc for heater blower resistors), can someone with access to a parts store have a rummage for a resistor with similar specs and a decent heat sink that we can use to replace ours with (with a new socket)? mjcp Quote Share this post Link to post Share on other sites
dragon green 4 Posted November 22, 2011 Found this on the wiki, it may help you http://wiki.the-corrado.net/fan_speed_thermal_fuse_repair.html Quote Share this post Link to post Share on other sites
rodmax 0 Posted November 22, 2011 Hi,the resistor pack in the 16v im breaking is good,give me a shout if you get stuck Thanks rod Quote Share this post Link to post Share on other sites
mjcp 0 Posted November 23, 2011 (edited) Thanks, I have replaced the thermal fuse and then replaced it again with a self resetting fuse too... that keeps getting hot and fusing. Therefore the resistor pack would seem to be getting too hot still. @Rod, how do you know it is OK? (I'm not suggesting its not!, this is part of my question) what readings *should* you get form a working one on a multimeter? For all I know, mine *IS* working and its the fan that's shagged, causing too much load making the resistor too hot...? mjcp Edited November 23, 2011 by mjcp Quote Share this post Link to post Share on other sites
rodmax 0 Posted November 23, 2011 Hi,i cant give you any readings,all i can tell you is that the fan operated fine Thanks rod Quote Share this post Link to post Share on other sites
Angelo Amato 10 Posted November 23, 2011 done one on a mk3 golf i had - it sat in the heat fan housing. expensive new (approx £43 from VW), so a trip to a scrappy to relieve one from a dead car ! Quote Share this post Link to post Share on other sites
