jonnykillpop 10 Posted December 29, 2011 Hello, my passenger seat is like new but the drivers one is worn on bolster etc. which I imagine is normal, on my Corrado VR6 94. On my Capri which has leather Recaros I just swapped them over as they are identical, runners and everything, just endd up with recliner wheel on inside which is'nt major prob. The Corrado's obviously are'nt uniform, is it possible to swap them if you change runners, and seatbelt holder catch? I'd look for other seats of an Audi TT or similar maybe, look nicer on modern Audi's but what would fit bearing in mind I have the Corrado seat on it's lowest height setting, cfor a nice driving position, ould imagine other seats sitting too high. Thanks Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 4, 2012 You may be able to remove the base foam and swap them around. Saw a thread on golfgtiforum today actually where someone did exactly that in a mk3 gti. It looks a bit long winded, and removing the foam was a bit of a pain in the arse, but it may be able to be done. Quote Share this post Link to post Share on other sites
dragon green 6 Posted January 4, 2012 Physically you can swap the seats, but the seat belt holder and all the seat controls are on the wrong side ! As above you might be able to swap the cushions, or a good trimmer should be able to sort it for you Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted May 1, 2015 Physically you can swap the seats, but the seat belt holder and all the seat controls are on the wrong side ! Sorry for bumping this back up. But is this correct, as it will save me the hassle of borrowing a drivers seat. To get my bolster repaired. As I want to still be able to drive the car back in the garage, whilst the seat is getting repaired. Quote Share this post Link to post Share on other sites
dragon green 6 Posted May 1, 2015 Yes I did it ! The only snag is,you have to clip the seat belt into the passenger side,I rarely take passengers,so for me wasn't a problem Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted May 1, 2015 Well that's great news, will try it on the banks holiday hopefully. I'm not really fussed about the seat belt, as I will be only moving the car on the drive and then back in the garage. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted May 6, 2015 Well did this swap at the weekend, and it wasn't quite as straight forward as it seemed. Had to remove the plastic guide in front of the seat, as I couldn't slide the seat in. Also you cant adjust the seat forward and back sat in the car, as the leaver is on the other side. However you can adjust it from outside of the car. But it will do, whilst I get the drivers seat repaired and saves the hassle of buying one or borrowing one. Quote Share this post Link to post Share on other sites
snowyhudson1971 10 Posted July 8, 2016 Hi i have done exactly this to mine, took out both front seats took them in the warm house and got started. took me about 2hours max, very simple indeed, the seat bases are easily unclipped and swapped over, mine were heated leather so i had to splice and re join the cables, simple job also, while i was there i unclipped the worn bolsters and swapped them over too, the only thing you cant swap over without a lot of hassle are the seat backs and upper sides, i know have a lovely new seat to sit in, cost was Zero. Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 8, 2016 I swapped the upper bolsters and was really simple. Its all one piece, and aside from removing the headrest guides it just pops straight off iirc. Quote Share this post Link to post Share on other sites
