Heardy 0 Posted March 21, 2004 Hi all, as you can tell i'm new on here. Can someone tell me the correct offset for a corrado VR6 is it them same as the Golf VR6? Also what tyre size would you reccomend on 16 inch rim's Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 21, 2004 et35-38 and go for 205/45/16's i think thats right :? Quote Share this post Link to post Share on other sites
Ka` 0 Posted March 21, 2004 I'm looking at the manual, for original wheels: VR6: 205/50 R 15 86 V On Wheel: 6 1/2 J x 15 ET 43 Cheers, Rica Quote Share this post Link to post Share on other sites
Heardy 0 Posted March 21, 2004 I might sound a bit daft but do you need to keep the offset the same if you are fitting larger wheels or does it change :? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 22, 2004 I might sound a bit daft but do you need to keep the offset the same if you are fitting larger wheels or does it change :? Not if you go wider, otherwise the tyre will rub on the inner arch. As Dazzy said, 35-38 is about right. Quote Share this post Link to post Share on other sites
Heardy 0 Posted March 24, 2004 Thanks for that i've just got to decide what wheel's to get :? Quote Share this post Link to post Share on other sites
