carrots 1 Posted February 17, 2012 hi i bought 2 second hand wings for my early 1990 corrado,the advert on ebay said they are off an early corrado.is there anyway to tell the differace between early and late wings just to make sure.ive done the filler repairs and got them in spray filler,just need to flat that down and primer them. Quote Share this post Link to post Share on other sites
Yandards 0 Posted February 17, 2012 They should be around 10mm less flare at the widest point of the arch - very difficult to tell unless fitted to a car though! Quote Share this post Link to post Share on other sites
carrots 1 Posted February 17, 2012 so when i get to fitting them , if they are late wings will they fit ok and look ok Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 18, 2012 I'm sure they will fit either way Quote Share this post Link to post Share on other sites
carrots 1 Posted February 18, 2012 ok cheers,hopefully get them in primer later today Quote Share this post Link to post Share on other sites
Yandards 0 Posted February 18, 2012 They do fit and if you fit a pair if it almost impossible to tell. Later wings will give a slightly wider arch when fitted so if that's a look you are going for.. Quote Share this post Link to post Share on other sites
RW1 0 Posted February 18, 2012 There were front bumper changes, but iirc, they are cosmetic only and shouldn't affect the fitment of the later wings. . Quote Share this post Link to post Share on other sites
