Kempy 0 Posted March 6, 2012 I got some grubby inner barrels on my splits. Has anyone got a suggestion on how I'd clean this? I didnt make them this bad this is how I bought them :( They will probably get painted but I'd like them as clean as possible first, is this something DIY'able thanks Ive tried nitromoors today but not very effective, its pretty tough to remove. Quote Share this post Link to post Share on other sites
easypops 8 Posted March 6, 2012 I'd use a fine grade sandpaper :) Quote Share this post Link to post Share on other sites
owen g60 10 Posted March 6, 2012 meguiars hot wheels is pretty good at shifting crap of wheels Quote Share this post Link to post Share on other sites
scarlet_vr6 0 Posted March 6, 2012 I've found that valet pro bilberry and meguiars wheel brightener are pretty decent but I'm not sure if you can buy them in anything less than 5ltr bottles Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
robo22sri 10 Posted March 6, 2012 http://www.autobritedirect.co.uk/index.php/purple-rain-iron-decontamination-remover.html this stuff is the nuts! will get rid of that! or try this http://www.espumadirect.co.uk/index.php?main_page=product_info&products_id=16 Quote Share this post Link to post Share on other sites
KADVR6 0 Posted March 6, 2012 if nitromoors aint touching it then just go and get them vapour blasted, and then powder coated or a diy paint job with some hammerite. Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 6, 2012 I doubt any megs will work if nitromors failed. anyone used caustic soda? someone on ed38 said this Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 6, 2012 Sand blast and powdercoating is the way forward.. Quote Share this post Link to post Share on other sites
KADVR6 0 Posted March 6, 2012 I doubt any megs will work if nitromors failed. anyone used caustic soda? someone on ed38 said this caustic soda will work, BUT it could actually eat the alloy depending on the grade of alloy used, if you dont wanna go down the shot/vapour blasting then get a 240 grade flap wheel and use a corded drill, this will shift it all but could look ****e afterwards, and for £20 a wheel to get them powdercoated i would not even bat an eye lid and just get it done properly. Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 6, 2012 I can get them shot blasted in my dads work but i'd say it would pit the ally, whats vapour blasting? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 6, 2012 ideally you wanna use walnuts, beads are fine depending on whats being used. shot will prob be too heavy, but not the end of the world if its the inside of the barrel.. Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 6, 2012 the inside looks pitted anyway tbh Quote Share this post Link to post Share on other sites
Stonejag 10 Posted March 7, 2012 caustic soda will work, BUT it could actually eat the alloy depending on the grade of alloy used If it works at all it will be because it's eating the alloy, surely? If it didn't then it wouldn't be able to clean the corroded top layer. Another coat for blasting and powdercoating here, easy and cheap with known good results. Or you could go for a combo, my wheels are black powdercoat with silver paint over the top and a clear powdercoat over the top of that, they look the mutt's nuts :) Stone Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 7, 2012 got it way cleaner but its massively pitted it turns out so I'll just send it over to the powdercoaters to prep and finish Quote Share this post Link to post Share on other sites
