akacheesy
How long does your VR6 take to warm up?
Define "warm up" - do you mean reach normal water temp or reach normal oil temp.
Reaching 60-70 degrees on the water should take 3-4 minutes at the most (except on VERY cold days), but reaching 85 degrees on the oil can take a lot longer than that.
mines takes around 5 mins i'd say, i'll check tomorrow :)
to get upto 80 odd on the oil takes just under 7-10 mins off the top of my head
If you're wanting to go for a blast that 7-10 mins seems an eternity!! :(
Worth the wait though :mrgreen:
I would say mine takes about the same amount of time
timo
If it is taking 9-10 miles for the water temperature to get to 60-70 degrees it may well be that your thermosat is stuck in the open postion. Just had the same problem on my VR6 and then it decided to stick in the closed postion and would over heat after 5 mins of driving, got it replaced and every thing is running fine again. Has it always taken a while for the water to heat up or is this something that has just started to happen?
10 mins for the water to get to 70 this morning, and over 15 for the oil to get to 80, but thats cos of the stupid traffic leaving Oxford.
As mentioned above, its the oil temp you wanna worrry about
VR always used to take a good while to warm up (well, until the thermostat siezed up!), but my 8v is hot in a couple of minutes and the oil gets up to 100 in no time at all.
I found 2 actually, but one was a heap of sh1t. and the other one, well, I bought it! VR6 going in it at Easter.
2 8v's......the only reason for buying it is that it was the cheapest way to buy a tidy late shell in a decent colour.
