DiElBramz 0 Posted March 29, 2012 Anybody got a brake compensator for my early 1.8 16V Rado? If not, any advice on what other cars I will find one on that will fit my car?? Quote Share this post Link to post Share on other sites
aide 0 Posted March 29, 2012 even if you find one on a rado or early golf, you'll be lucky if it hasn't seized onto the beam bracket and needs cutting off which is tricky to do without wrecking it. you can buy the original ate item of ebay. Quote Share this post Link to post Share on other sites
DiElBramz 0 Posted March 29, 2012 Not seeing any on Ebay!! Can you link me?? Quote Share this post Link to post Share on other sites
aide 0 Posted March 30, 2012 found this in a rush so double check its the correct part for you, i couldn't find the old supplier, but seems GSF are selling them online now. http://www.ebay.co.uk/itm/Brake-Pressure-Regulator-Replaces-ATE-type-VW-without-ABS-/280823723525?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item416265f605 Quote Share this post Link to post Share on other sites
RW1 0 Posted March 30, 2012 aide said: found this in a rush so double check its the correct part for you, i couldn't find the old supplier, but seems GSF are selling them online now. http://www.ebay.co.uk/itm/Brake-Pressure-Regulator-Replaces-ATE-type-VW-without-ABS-/280823723525?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item416265f605 It actually states not compatible with a 16v in the drop down compatibility selection. All other models than VR6 are Part No.: 357 612 151 This is genuine ATE. http://www.ebay.co.uk/itm/VW-CORRADO-GOLF-MK2-GTI-BRAKE-PRESSURE-REGULATOR-C46-/200602586830?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eb4d88ece (For a VR6. ie. Part No.: 1H0 612 151C And Tierod sells that as genuine ATE part here. http://www.ebay.co.uk/itm/GOLF-MK3-GTI-VR6-CORRADO-BRAKE-PRESSURE-REGULATOR-C72-/200704548022?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ebaec5cb6) . Quote Share this post Link to post Share on other sites
dragon green 6 Posted March 30, 2012 I bought the top one that RW1 posted above, top service from the seller, Highly recommended Quote Share this post Link to post Share on other sites
StueyB 0 Posted March 30, 2012 Dropped you a pm, have a good condition 2nd hand item. Quote Share this post Link to post Share on other sites
rodmax 0 Posted March 30, 2012 I have one if you get stuck Thanks rod Quote Share this post Link to post Share on other sites
