truthteller 10 Posted April 8, 2012 hi i have a 1995 2.0 16 valver the spoiler works fine when using the switch it lifts and lowers within the 5 second time scale that it should but however does not operate based on speed after reading many things i have understood that there is a relay that controls the spoilers actions based on speed but i can not find it lol can anyone please tell me where it is? Quote Share this post Link to post Share on other sites
P3rks 11 Posted April 8, 2012 I believe it's a larg-ish relay (a black box) behind the clocks. I have read somewhere that the speed sensor on back of the clocks can also fail. Also, have you fitted a aftermarket stereo by any chance? The most common issue is that there is a wire which goes into the original stereo which give a speed signal. This needs to be unplugged into anything otherwise it disrupts the speed signal and stops the spoiler working. Quote Share this post Link to post Share on other sites
owen g60 10 Posted April 8, 2012 Remove the cover by the bonnet release cable ( should be 2 pull tabs holding it) then look directly up inside the dash. That is where the spoiler relay is. Easiest way to remove it is to remove the clock surround(4 screws) then the dash vent. (pop the vent out the housing and remove the screw) You can now access the relay from where the vent was Quote Share this post Link to post Share on other sites
truthteller 10 Posted April 8, 2012 hi guys thanks for the replies yea the previous owner fitted a after market stereo and if i was to go buy anything he has done then i would say that may be a factor to take into consideration. cheers for the instructions that will save me a hour or two trying to get my head around it lol i will have a look over today and tomorrow Quote Share this post Link to post Share on other sites
rodmax 0 Posted April 9, 2012 If you do end up needing a relay,give me a shout as i have a spare one Rod Quote Share this post Link to post Share on other sites
truthteller 10 Posted April 9, 2012 thanks that sound of you to offer is there anyway i can test the relay without replacing it? Quote Share this post Link to post Share on other sites
