carrots
spoiler adjustment
hi i took my rear spoiler off because the car was having a respray.ive refitted it but now its loose,you can lift it up a little so i reckon it will rattle.is it possible to adjust them
Sounds like the two Allen screws have come loose !
Take them out,and make sure you put loctite/thread sealer on them,
There's a lot of wind vibration that will loosen the bolts.
You may not of done the bolts up tight enough !
The bolts go into a captive nut,that's in a small slot,so you can adjust the height of the spoiler to make sure it's level !
