STORM 2
URGENTLY require offside sill / both sills
failed MOT due to corroded rear aspect of offside sill - anyone got any lying around or knows somewhere to source them?
Do VW still sell them?
hi Jon - thanks for that - most of the corrosion is toward the rear of the sill as it becomes the rear wheels arch - am I correct in thinking this is not an available part? Anyone with ETKA, can they tell me what part number is on MG[8], SG[09], illustration [142]?
cheers
see attached ETKA picture from somewhere else on forum!
etka.pdf
Edited by STORM 2
Got these..?
Pretty much full length sill sections.
Hi Stuey
Are these the middle box sections? (see part 12 in the ETKA photo) Can you tell me what length they are?
cheers
Yep they are the part 12's in the ETKA picture and they are as long as I could possibly cut out from the shell so at least the same as repair panel size if not bigger/longer.
Cut throw to the thin floor of the car so you have all the sill metal to work with.
Up for £35 each.
Doh, beat me to it
Sorry for the brief hijack - do you have a part # and description for item 6 in that pic? I definitely need both front sections but not sure about the inner bit...
Thanks!
[TABLE=width: 100%]
[TR]
[TD=bgcolor: #E1E1E1][TABLE=width: 100%]
[TR]
[TD=width: 50, align: center]6[/TD]
[TD]535809621C[/TD]
[/TR]
[/TABLE]
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD=bgcolor: #D7DBD3][/TD]
[TD][/TD]
[/TR]
[TR]
[TD=bgcolor: #D7DBD3]reinforcement for pillar a
left lower /[TABLE=width: 100%]
[TR]
[TD=width: 50, align: center](6)[/TD]
[TD]535809622C[/TD]
[/TR]
[/TABLE]
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD=bgcolor: #E1E1E1][/TD]
[TD][/TD]
[/TR]
[TR]
[TD=bgcolor: #E1E1E1]reinforcement for pillar a
right lower /[/TD]
[/TR]
[/TABLE]
Now less hijacking Mr Jag.
cheers Stuey, but most of my corrosion is in the end part where it forms the rear wheel arch, so I'm looking at patch welding or a new whole rear wing
