carrots 1 Posted April 29, 2012 my corrado dont feel right on round abouts,if i an going quick it feels like the steering wheel is moving from left to right.ive orded some poly wishbone bushes even tho some say they are crap and to use r32.has anyone else got this problem.my mechanic mate reckons its because its lowered Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 29, 2012 Was the tracking and camber done after it was lowered? That'd be my first port of call anyway. Quote Share this post Link to post Share on other sites
carrots 1 Posted April 29, 2012 tracking was done when i changed the wishbones a while back.how do you adjust the camber Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted April 29, 2012 you need to get a full geometry setup, tracking alone isnt enough. the geometry setup will adjust the camber, caster as well as the toe in/out Quote Share this post Link to post Share on other sites
carrots 1 Posted April 29, 2012 how do you adjust the camber tho,trackrod ends for toe in or tow out but i cant see anything that would adjust the camber Quote Share this post Link to post Share on other sites
floppyman 0 Posted April 29, 2012 Camber is adjusted on the balljoint and where the hub bolts into the shock... You cant really adjust it without laser machines. Quote Share this post Link to post Share on other sites
carrots 1 Posted April 29, 2012 ok cheers i wouldnt of thought there would of been much adjustment there tho Quote Share this post Link to post Share on other sites
james153 0 Posted April 29, 2012 ok cheers i wouldnt of thought there would of been much adjustment there tho theres tons of adjustment there about +2 to - 4 degrees, enough to change the cars handling by alot. Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted April 29, 2012 my car needs wheel alignment but it feels fine in the corners, i dont think the problem to your question is wheel alignment but worth getting done, Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 29, 2012 Depends if its camber related though. Neg camber and its fine when cornering. Pos camber and theres very little contact with tyres and road. Same with the Toe. Toe out and its gonna be very skittish indeed when cornering! Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted April 29, 2012 Just re-read your original post. How low is it? Too low can have adverse affects. Quote Share this post Link to post Share on other sites
carrots 1 Posted April 30, 2012 not sure how low because it was like that when i bought it.its not as low as some ive seen Quote Share this post Link to post Share on other sites
