swampy
Stainless steel engine fittings uprated suspension bolts
Hi all.
as a side line from the brakelines I can also supply stainless steel bolts in almost any length and specification.
I am willing to design and supply sets for the Corrado but as i dont have one to work from I need your help in designing them
for other cars i do them for inlet manifold, exhaust manifold, cam covers, headlight mounts, wing bolts etc
what I aim to do with your help is build kits for the forum containing all or parts of these, but can you kind people supply with me numbers and lengthes of bolts for each purpose
so far i can do cam cover bolts and inlet manifold bolts for the KR engines
secondly I do uprated grade suspension bolts, these are wishbone bolts, pinch bolts, shock absorber mounts etc
again if you can supply the lengthes and pitch and bolt size then i can start building kits to replace these parts.
the grade would be 10.9 or 12.9 grade so as good as if not better than standerd.
SO ANY BOLT TYPE YOU WANT JUST ASK AND TOGEATHER WE CAN SOURCE AND SUPPLY THEM
How About joining forces with the 312 mm brake guide to supply the longer high tensile bolts needed for the conversion , i think all the info is on that guide but it would be nice to order the lot in a complete set for the job
I would be interested in the front hub-strut nuts and bolts and rear beam-shock nuts and bolts. These are available from VW, but the quality is not that great as they deteriorate pretty quickly I've found.
Same for carrier bolts for front and rear. And the wishbones bolts mentioned. I'd def be up for a kit as it's one of the areas that annoy me. Nivce new, high quality fasteners will help ensure the car is easy to work on for years a well as preventing the usual issues consequences of rust taking hold on bolts.
Great idea :)
hmm have a read of the thread and cant find any dimensions of the bolts
---------- Post added at 10:11 PM ---------- Previous post was at 10:10 PM ----------
Great idea :)
not a problem, im sure i can help just need to find the dimesions
if any one has any ols suspension bolts and knows what they are and where they come from but not sure how to get me the specs then they can send me the bolt and in return ill do them a discount off a new set
[TABLE=width: 583]
[TR]
[TD]Don't know if this helps at all, I started making a list of bolts to change on my 16v a couple of years back:
16v part[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD] [/TD]
[TD]bolt P/N[/TD]
[TD]Size[/TD]
[TD]type[/TD]
[TD]No. used[/TD]
[/TR]
[TR]
[TD]oil filter housing with washer[/TD]
[TD][/TD]
[TD]M8x25-Z3[/TD]
[TD]allen[/TD]
[TD=align: right]4[/TD]
[/TR]
[TR]
[TD]water pump pulley[/TD]
[TD]N 903 086 03[/TD]
[TD]M8x14[/TD]
[TD]allen[/TD]
[/TR]
[TR]
[TD]thermo-housing[/TD]
[TD]N 010 222 8[/TD]
[TD]M6x22[/TD]
[TD]hex[/TD]
[TD=align: right]2[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]water pipe to head[/TD]
[TD]N 014 703 5[/TD]
[TD]M6x18[/TD]
[TD]allen[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]CSV to manifold[/TD]
[TD]M6x18[/TD]
[TD]allen[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]water pipe to engine mount front[/TD]
[TD]N 010 215 27[/TD]
[TD]M6x15[/TD]
[TD]hex[/TD]
[TD=align: right]1[/TD]
[/TR]
[TR]
[TD]water flanges to head[/TD]
[TD]N 010 217 10[/TD]
[TD]M6x20[/TD]
[TD]hex[/TD]
[TD=align: right]5[/TD]
[/TR]
[TR]
[TD]PAS pulley to pump[/TD]
[TD]N 014 706 2[/TD]
[TD]M8x12[/TD]
[TD]allen[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]PAS tension bracket to block (side)[/TD]
[TD]N 010 340 4[/TD]
[TD]M8x40[/TD]
[TD]hex[/TD]
[/TR]
[TR]
[TD]PAS bracket to pump (front)[/TD]
[TD]N 010 242 22[/TD]
[TD]M8x25[/TD]
[TD]hex[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]PAS bracket to pump (side)[/TD]
[TD]N 010 241 18[/TD]
[TD]M8x22[/TD]
[TD]hex[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]PAS bracket to block (front)[/TD]
[TD]N 010 345 10[/TD]
[TD]M8x45[/TD]
[TD]hex[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]N 010 385 7[/TD]
[TD]M8x85[/TD]
[TD]hex[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]PAS bracket to alt bracket (front)[/TD]
[TD]N 100 113 01[/TD]
[TD]M8x140[/TD]
[TD]hex[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]rear suspension leg bottom[/TD]
[TD]N 905 173 02[/TD]
[TD]M10x75[/TD]
[TD]hex[/TD]
[/TR]
[TR]
[TD]self locking nut[/TD]
[TD]N 102 090 05[/TD]
[TD]M10[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]crank breather unit to block with washer (early)[/TD]
[TD]N 100 227 01[/TD]
[TD]M8x38Z3[/TD]
[TD]allen[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]crank breather unit to block (late)[/TD]
[TD]N 014 710 7[/TD]
[TD]M8x20[/TD]
[TD]allen[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]rear bumper[/TD]
[TD][/TD]
[TD]M10x33[/TD]
[TD]flanged hex[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]wishbone rear bush[/TD]
[TD]191407181D[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]top mount (early passat type)[/TD]
[TD=align: right]357412329[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]wishbone front bolt[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]wishbone rear bolt[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]subframe rearmost bolt 13mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]clutch 2E engine 1994[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]arb droplink complete[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]inner roll bar bush[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]front susp leg bottom bolt[/TD]
[TD]N 903 237 04[/TD]
[TD]M12x1.5thread[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]front susp leg bottom bolt nut[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]front wishbone bolt[/TD]
[TD]N 904 840 03[/TD]
[TD]M12x1.5x82[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]hub to balljoint pinch bolt[/TD]
[TD]N 903 289 01[/TD]
[TD]M10x50[/TD]
[TD]got[/TD]
[/TR]
[TR]
[TD]hub to balljoint pinch bolt nut[/TD]
[TD]N 102 861 02[/TD]
[TD]M10[/TD]
[TD]got[/TD]
[/TR]
[TR]
[TD]rear wishbone bolt[/TD]
[TD]N 102 078 03[/TD]
[TD]M12x1.5x78[/TD]
[TD][/TD]
[/TR]
[/TABLE]
That's just what I want
Are the suspension bolts the same across the range??
I just spent about £600 on bolts and screws from vw :(
Got a good list of the types and sizes now though if its useful, for a late vr6.
Sent from my X10i using Tapatalk 2
That would be really handy if you could post that up for others 3CM....
Mark
If you could do that it would be great could you email me it at
[email protected]
here are the first few prices, where ever possible bolts will be 12.9 so most will have a socket cap head.
if you want them with a hex head they would be in 10.9 grade, where ever possible the bolts will be zinc coated to aid anti corrosion
front wishbone bolt £7 pair with new washers and nylocs
hub to balljoint pinch bolt £5 the pair with new nylocs and washers
rear wishbone bolt £7 the pait with new nylocs and washers
does any one have the sizes for the rest of the suspension bolts?
Front subframe bolts are:
M12x1.5x82 42mm shoulder
M12x1.5x65 25mm shoulder
M12x1.5x78 38mm shoulder
M10x24 full thread
and a picture for reference.
Oh they are a bit specialised I'm going to have get under a car and check a few
Most of the engine mounting/ suspension fasteners are of the above pictured design. if you need any more pictures of specific bolts i could sift through my collection.
Matt
