TanVr6 0 Posted June 5, 2012 Im in need of a bit of guidance with removal of the rear wiper! As I personally don't use it and prefer the C without it. I'm removed the wiper and wanted to know a few things before I remove the rear wiper motor. 1. Where should I disconnect the washer hose from to stop the screen wash going to the back and flooding my boot...? 2. Is there a seperate fuse that I can take out to stop the rear wiper functioning??? Any other tips or pointers would be much helpful Quote Share this post Link to post Share on other sites
v8rumbler 0 Posted June 5, 2012 When I did mine I put a squirt of silicone in the tube.once dry your boot will stay dry Quote Share this post Link to post Share on other sites
Nathan Harvey 10 Posted June 5, 2012 I took mine out the other week , i used a screw in the washer line , just don't go to operate it. The fuse i think is shared with mirrors and sunroof so can't do much about that one. Quote Share this post Link to post Share on other sites
Chrisvw419 0 Posted June 5, 2012 I also removed mine recently, I disconnected the in the engine bay and then plugged it with a screw. No chance water in the boot at all then! Quote Share this post Link to post Share on other sites
TanVr6 0 Posted June 5, 2012 Thanks guys! I think I will try to locate the pipe in the engine bay n disconnect it. Quote Share this post Link to post Share on other sites
TanVr6 0 Posted June 5, 2012 Chrisvw419 said: I also removed mine recently, I disconnected the in the engine bay and then plugged it with a screw. No chance water in the boot at all then! Any chance of a picture of this, so I remove the right one. I'm a complete noob when getting my hands dirty under the bonnet of a car! Quote Share this post Link to post Share on other sites
Chrisvw419 0 Posted June 5, 2012 I will try and get you a photo tomorrow. All you need to do is follow the washer tubing from the front jets to the bottle and then you will notice another heading towards the back of the car, obviously this is for the rear washer jet. Disconnect this one at the motor and plug the rubber connector. Quote Share this post Link to post Share on other sites
TanVr6 0 Posted June 5, 2012 Thanks, I know it will be pretty simple for most but I'm a complete noob under the bonnet! Quote Share this post Link to post Share on other sites
